Method to disable auto stop / start found
X_Kris_X
Vehicle: Ford Ecosport 1.0 Ecoboost 140KM ASB
Re: Method to disable auto stop / start found
Post by X_Kris_X »
semiho wrote: Thu Oct 03, 2019 9:55 pm
Focus-MK4 wrote: Fri May 10, 2019 3:58 pm I wanted to try it on the new Focus 2019 but the BdyCM hasn´t the 726-48, it´s only up to 726-27
Anyone an idea?
BCM’s are quite different, so configuration byte of S&S is also different for Focus/Kuga/Escape/C-Max etc.
does anyone found the configuration byte for those models? I have the same on EcoSport (it´s only up to 726-27) :/
ted22
Vehicle: escape 2.0 2016
Post by ted22 »
Any luck finding this anyone??? same on the Lincoln MKC... only goes up to 27.
Baltic
Vehicle: Ford Transit Custom 2018. 2.0 EcoB 95kW
Post by Baltic »
Hello all!!
Must register to here and buy Forscan.
Is this method still valid and what those XXX are in coding? Bit confused :shock:
Transit Custom
lenko
Vehicle: 2015 Lincoln MKC(Sold), 2006 Mustang GT, Saleen 530 HP
Post by lenko »
Baltic wrote: Wed Feb 26, 2020 12:56 pm Hello all!!
Transit Custom
Still available and the X's are the positions of letters or numbers you don't touch when programming.
Baltic
Post by Baltic »
Ok now I get it, thanks!
Will try this when my cable arrives.
don't forget to backup the modules when the cable arrives ;)
https://www.youtube.com/watch?v=4Opz1oa2_n0
arrgh
Vehicle: Ford Fiesta VI 1.5 95CV 2016
Post by arrgh »
Same here, with Focus Mk4 and Fiesta ST Mk8, BdyCM doesn't have the address mentioned, it goes only up to 726-27. BTW, I've successfully disabled the menu in the IPC, the address mentioned is present and working, menu in IPC has gone. Also tried to set the start/stop bit in APIM, but nothing changes, the start/stop is always enabled. Anyone have another BdyCM address to test? If yes, I can test it.
Fresh_1
Vehicle: 2019 Ford F150 3.5 EcoBoost
Post by Fresh_1 »
Airborne_Ape wrote: Tue Mar 07, 2017 7:17 am
BCM 726-48-02 x0xx xxxx xx
I tried it on a 2019 F-150 XLT and it appears to be working. Anyone know what this actually changed?
f-wolf
Vehicle: *** Ford ***
Post by f-wolf »
Fresh_1 wrote: Wed Mar 04, 2020 2:37 pm
Engine stop.jpg (22.68 KiB) Viewed 10106 times
jejuda
Vehicle: F-150, 5.0 liter/Gasoline, 2018
Post by jejuda »
Easy, Works on 2018 F-150 XL
FCIM Configuration Module
"Start/Stop Button Disable" Enable to Disable
IPC Configuration Module
"Auto Engine Shutdown with Memory" Enable to Disable
BdyCM As Built Module
726-48-02 x1xx to x0xx (first 4 digits)
