devele
Vehicle: Ford Fiesta 1.4 TDCI
Post by devele »
No. I don't have it,... I bought JDiag Elite-II as a little cheap and reliable, anybody who use this device please share their experience to me
thanks in advance.
devele
Post by devele »
Even I tried on VINT the same thing happens, I tried it on FORD Fiesta 2010 model with Siemens ECU the programming and service procedure is not available, what could be the problem
Norbi_wo
Vehicle: Ford Fusion 2.0 Ecoboost 240KM, 2014
Post by Norbi_wo »
Hello.
Today I used klon mongoose jlr plus (SP-205c with orginal driver for windows 7 64 bit) with forscan 2.3.29 beta. I conected with ford focus St mk4 it's perfectly worked.
There is another adapter used with FORScan. The original VCM I was tested and passed similar to:
CarDAQ Plus
CarDAQ Plus 2
1st test
1st test
Test 01.JPG (230.82 KiB) Viewed 15712 times
3rd test
3rd test
Test 03.JPG (110.48 KiB) Viewed 15713 times
2nd test
2nd test
Test 02.JPG (133.28 KiB) Viewed 15713 times
VCM 1 Connection
VCM 1 Connection
VCM 1.jpg (192.07 KiB) Viewed 15713 times
1st test
1st test
Test 01.JPG (230.82 KiB) Viewed 15713 times
3rd test
3rd test
2nd test
2nd test
ahmadtow
Vehicle: MONDEO IV,2.0 TDCI 2.0,140h,2008
Post by ahmadtow »
devele wrote: Thu Feb 06, 2020 4:33 am No. I don't have it,... I bought JDiag Elite-II as a little cheap and reliable, anybody who use this device please share their experience to me
thanks in advance.
I have JDiag elite pro II test it with Xentry and DAs and VIDA and Forscan all good will test it more when i have time
Daone2021
Vehicle: 2006 Ford Explorer 4.0L
Post by Daone2021 »
I have a Cardaq plus 1 and 2 along with original VCM II. Which one will work best with this program. Also, does this do flashing like IDS and FJDS? Or is flashing/programming only done through Ford? Thank you! New here. :)
aircraftru
Vehicle: Insignia, A20DTE, 2000cc/96kW, 2014
Post by aircraftru »
Did someone is run MDI interface? Is work with GDS, but can’t figure way to run with ForSCAN
Keithmac
Post by Keithmac »
I've been using a 2 board clone VCM2 with our 2013 Kuga.
Has worked flawlessly with FORScan, did a Powershift TCU furmware update in less than 5 minutes without issue.
Wasn't the cheapest available, sourced from Germany but works a treat.
light
Vehicle: FORD focus
Post by light »
CantieCAR Ford mondeo body module programming "CAN bus compatibility problem"
any solution ??
raftrading
Vehicle: transit 2200 tdci 2007
Post by raftrading »
Has anyone tried a autel maxiflash j2534? I can't get forscan to find mine?
