SHARKTEETH
Vehicle: 10 f150 5.4
Post by SHARKTEETH »
i have a 2010 F150 and i am looking for a the right cable to use. I found this cable and was wondering if it would work. It says 16 pin.
OBD2 to USB Port Adapter Cable, EEEkit 1M/3.3ft 16Pin OBD 2 Female to USB Male Port Diagnostic Tool Charger Adapter Cable Connector
any help would be appreciated.
Robert
r4w
Vehicle: Mazda 6 tourer
Post by r4w »
fordsmax471 wrote: Sat Apr 25, 2020 11:40 am
r4w wrote: Fri Apr 24, 2020 2:06 pm Hi,
New here from UK and looking for the best adaptor on the UK market (USB) to use it with FORscan. Do you have any recommendations, from either eBay or Amazon or anything I can pay with PayPal so I can return if it doesn't fit my expectations?
Thank you!
google search or ebay search
OBDLink EX usb or els27v4 usb
Thanks, I did look around for them but they're both around 80 pounds shipped. I can get for a bit more a SVCI J2534 if I have to spend that much :) Any Chinese clone recommendations?
darrenboddy
Vehicle: 2019 F350 6.7L
Post by darrenboddy »
New member! Hi~
I only have apple products (iOS) and it seems like everything I have seen on here is geared for Microsoft users. I purchased a (OHP ELMconfig FORScan OBD2 USB Adapter for Windows, Ford Diagnostic ELM327 Coding Tool with MS-CAN / HS-CAN Switch) but fear it will not work on my application.
Thoughts?
vvmaks
Vehicle: 2015 Ford Expedition
Post by vvmaks »
darrenboddy wrote: Tue Jun 16, 2020 2:12 am I only have apple products (iOS) and it seems like everything I have seen on here is geared for Microsoft users. I purchased a (OHP ELMconfig FORScan OBD2 USB Adapter for Windows, Ford Diagnostic ELM327 Coding Tool with MS-CAN / HS-CAN Switch) but fear it will not work on my application.
Thoughts?
For iOS, FORScan recommends OBDLink MX+. For Windows, OBDLink EX is your best option.
Kind regards,
Vitaliy
davecm
Vehicle: Mondeo Mk5 Titanium Ecoboost 240
Post by davecm »
I bought the ELS27. Very happy with it. Worked first time, no switch needed, super quick in use, good build quality and cable.
Only downsides are high price and the fact the manufacturer seems not to have heard about airmail or DHL, and they only ship it by standard Russian postal service. I ordered from manufacturer's Ebay store and it took 5 weeks to arrive, presumably by boat, from St Petersburg. Much longer than than advertised delivery time. I would have happily paid extra for courier delivery.
geebee0316
Vehicle: Escape 2.0L GTDI EcoBoost 2015
Post by geebee0316 »
vvmaks wrote: Mon Jul 13, 2020 7:08 pm
Thoughts?
Kind regards,
Vitaliy
I own an OBDLink EX and I am going to order an MX+ soon for advanced options. I had some questions and their support team is so responsive and helpful. The build quality is really great as others have stated...
richvollberg wrote: Tue Feb 25, 2020 4:06 am Update to my post above. The first EX unit I got had a bad USB cord. I contacted OBDLink and they sent out a new unit ASAP. It instantly conected and I had all the functions I was Looking For!.
Great Company and products. Working in the manufacturing field I understand that a Bad part gets sent out at times. Working on robots and PLC's we often order double the parts because the first one never works... :D
I already did the mods I wanted like horn off and DRL to fogs, Global window up and down from fob. Bambi Mode. Mirror heater on with remote start.
This is a awesome tool and just added a couple thousand dollars value compared to other stock f-150 Sports XLT with the snow plow option.
I highly recommend supporting this company, I own a Snap-On Solus Edge, a Drew-Tech Cardaq Plus 2 and a bunch of Fluke and Fieldpiece equipment so I have had the good fortune of using high-quality tools and the OBDLink EX that I now own is top notch.
Gary
fido
Post by fido »
Hello.
I have Viaken STN1170 V3.3.1 (ELM327 v1.3a) cable, will it be good for APIM update?
remy16
Vehicle: Ford Transit MK5 EJAXML, 4EB 2,5 TD 73.6KW 1995
Post by remy16 »
Hello FORscan community
I just tried the Obdlink EX USB module.
It is recognized by the PC (W7) but it does not recognize the 1995 Ford Transit 2.5l TD vehicle. The vehicle is equipped with a 16-pin obd socket and a 95V89J464 AA computer.
Could someone tell me the correct parameters to set for obdlink EX,
Thank you
Translated by Google
prise FDS ODB.jpg (108.18 KiB) Viewed 17275 times
f-wolf
Vehicle: *** Ford ***
Post by f-wolf »
remy16 wrote: Sat Oct 17, 2020 3:25 pm Hello FORscan community
Thank you
Your 1995 Ford Transit is too old !!
Your System
New System
adrianopery
Vehicle: Ford Ecosport 2018
Post by adrianopery »
FORScan wrote: Fri Mar 30, 2018 9:52 am Update 2019-12-11. Article updated as the following:
- Added reference to OBDLink EX
1. Protocols
Table 1.1 - Ford protocols
OBDII name / Ford name OBDII jack pinsBus speedBus min. response timeHow to detect
SAE J1850 PWM / Ford SCP2, 1041600 bps20...40 msImage
ISO9141 / Ford ISO79600 bps150...250 msImage
CAN / Ford HS CAN6, 14500 Kbps0...20 msImage
/ Ford MS-CAN3, 11500 Kbps0...20 msImage
/ Ford UBP310400 bps150...250 msImage
P - primary protocol (PCM)
GenerationSAE J1850 PWMISO 9141CANFord MS CANFord UBPComment
Ford 1996 - 2003PS---
Mazda 1996 - 2003-P---Some models used SAE J1850 PWM as primary
Ford EU, Mazda 2004 - 2009-SPS-Some models used SAE J1850 PWM as primary
Ford NA 2004 - 2009-SPSS
Ford, Mazda 2010+--PS-HS2, HS3 through MS-CAN
Focus Mk2 - only HS-CAN and MS-CANMondeo Mk3 after restyling - J1850, ISO9141, HS-CAN, MS-CAN
ChipSAE J1850 PWMISO 9141CANFord MS CANFord UBPAdapter
ELM327 standardXXX--ELM327, Kiwi 3
ELM327 with HS/MS switchXXXX-ELM327 marked as Ford, Mazda compatible
STN 1100XXX--OBDLink SX/LX
STN 115xXXXX-OBDLink MX BT
STN 1170XXXX-ELS27 (old versions), Viaken STN1170
STN 2120XXXX-ELS27 (new version)
STN 2255XXXX-OBDLink MX+
STN 2230XXXX-OBDLink EX
2. Performance
AdapterChipInterfaceMin.interface
response time
Max.interface
baud rate
Comment
ELM327 OHP HS/MS WiFiELM327 (clone)WiFi30-40 ms38400 bpsUnknown manufacturer - "good clone". Recommended only for iOS
Kiwi 3ELM327 compatibleBluetooth Low Energy40 ms-Can be used only with FORScan Lite for iOS
ELM327 HS/MS USBELM327 (original)USB0..2 ms500 Kbps
OBDLink EXSTN2230USB0..2 ms2MbpsRecommended for FORScan for Windows
OBDLink SXSTN1100USB0..2 ms2Mbps
OBDLink LXSTN1100Bluetooth--
OBDLink MX+STN2255Bluetooth6..20 ms-Recommended for FORScan Lite for iOS, Android
OBDLink MX BTSTN115xBluetooth8..20 ms115200 bps
OBDLink MX WiFiSTN115xWiFi-115200 bpsWiFi interface works unstable - it freezes and times out. Strongly not recommended!
ELS27 v3STN2120USB, Bluetooth0..2 ms USB, 20 ms BT8 Mpbs USB
Viaken STN1170 USBSTN1170USB0..2 ms2 MbpsLast versions of this adpater have buggy firmware 4.3.x. Recommended to downgrade to stable 4.1.1 or upgrade to stable 4.5.1
Viaken STN1170 BTSTN1170Bluetooth20..30 ms38400 bpsUses cheap BT chip so may freeze on some cars. Not recommended
Examples:
Example 1: Ford Mondeo Mk3 PCM, bus J1850. Adapter ELM327 OHP HS/MS WiFi. According to the table 1.1, let's assume min. bus response time is 20 ms, bus baud rate is 41600 bps. According to the table 2.1 adapter's min response time is 40 ms, baud rate is 38400 bps.
Overal min.response time = 40 ms + 20 ms = 60 ms
Overal baud rate = MIN ( 38400 / 2, 41600) = MIN ( 19200, 41600) = 19200 bps.
Note: we divide interface baud rate by two because ELM327 family adapters exchange data in text format. So every machine byte is represented in 2 transferred bytes.
As we can see, the adapter significantly limits the overal system peformance in this example (in case of cars with CAN bus, like Mondeo Mk4 or Mk5, the test results would be much worse). Is that bad? Well, it depends on your goals. If reading DTC and some PIDs is the only objective you have, it is not too important. But if you plan to read PIDs in real-time (or as much close to it as possible) or perform programming (actual for CAN bus), then this adapter is a bad choice.
Example 2: Mazda 323 2001, bus ISO. Same adapter.
Overal min.response time = 40 ms + 250 ms = 290 ms
Overal baud rate = MIN ( 38400 / 2, 9600) = MIN ( 19200, 9600) = 9600 Kbps.
In this case the adapter is OK, because the bus itself is very slow. Reponse time is less than 20% higher than maximum possible for this car, and transfer speed is also limited by the bus.
Example 3: Ford Fusion 2015, bus CAN. Adapter ELS27 v3 USB. Let's assume CAN bus response time is 0 ms, and adapter has 2 ms of response time and 2 Mpbs baud rate.
Overal min.response time = 2 ms + 0 ms = 2 ms
Overal baud rate = MIN ( 2000000 / 2, 500000) = MIN ( 1000000, 500000) = 500 Kbps.
So in this case the response time is minimal, and baud rate is limtied by the CAN bus one.
3. Reliability
4. Recommendations
P - recommended for programming: complex configuration, firmware update (only for CAN )
AdapterFORScan for WindowsFORScan Lite for iOSFORScan Lite for Android
OBDLink EXD, C, PNONO
OBDLink SXD, C, P*NONO
OBDLink LXD (if MS-CAN is not required)NOD (if MS-CAN is not required)
OBDLink MX+D, CDD
OBDLink MX BTD, CNOD
OBDLink MX WiFiNONONO
ELS27 v3D, C, PNOD
Viaken STN1170 USBD, C, PNONO
Viaken STN1170 BTNONONO
* - can be modified for MS-CAN support as described here.
5. Links to original adapters
All of these adapters were tested by us.
5.1. OBDLink product line: https://www.obdlink.com/
5.2 ELS27: http://els27.ru
5.3. Viaken: https://viaken.pl/pl/polski-elm327-v3-f ... -2014.html
Hi guys, I would like to know if we have any other new option to use as Bluetooth device?
An updated list!
