help with ford sync 3 apim firmware programing
performanceisland
Vehicle: 2015 Ford F350 Platinum
Post by performanceisland »
So i took a chance and it errored out, now i have dead apim, tried reset, have not tried ids programmable module installation yet, as i do not have a sync 3 car here, but wondering if there is anything else i can try with forescan? I noticed the last two current versions are not showing, see pics. there doesn't appear to be an option to program one thing at a time either.
PS any update on a full working version for firmware or is that still a long time away?
brad2388
Vehicle: 2019 F350 6.7 Diesel, 2019 F150 3.5 Ecoboost
Re: help with ford sync 3 apim firmware programing
Post by brad2388 »
Did u get it?
I have a failure too it stopped in the middle.
What i did was just write the illumination file by itself. It took it ok and problem solved.
performanceisland
ill try that also having problems getting files, i also think I am using an older beta of 2.4.0 mine says its test 20190909, someone mentioned there is a newer version, can someone email that to me on here or give me a link to it? that might be part of my issues.
the illumination file is which one? in my version of forescan it doesn't say illumination anywhere, the two options for ECU configuration are base and sound.
Andyfocus
Vehicle: ford focus 1.0 ecoboost
Post by Andyfocus »
JoshArmour
Vehicle: 2018 Ford Expedition Platinum Max
Post by JoshArmour »
I’m also wanting to do this, and I have the obdlink ex and have purchased a lifetime extended license. Before I attempt this, I’d like to know that someone has done it.
LaForge
Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
Post by LaForge »
APIM Upgrade is at this point NOT supported by Forscan 2.40.X
You have to read the text from Forscan team which is deployed with the file.
It clearly says NO APIM Update.
You have to wait until its official supported in another Beta or the final Version 2.40
regards
Karsten
Changed on my 2011 Focus:
lordwader
Vehicle: ford kuga 1500
Post by lordwader »
I have strange situation, trying to update firmware of APIM according cyanlabs description:
1. download
2. test run SBL
3. PROBLEM - should be program, but this button is invisible after above procedure
is it some new bug? any ideas how how to solve problem?
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
Master reset.
lordwader
Post by lordwader »
Ghano38 wrote: Thu Jun 04, 2020 11:30 am Master reset.
what You mean??
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
In Sync menu you can make a master reset of all settings.
