if you are using a FORScan old car profile that displays an APIM module, the old original software may have been successfully installed
I have done this once with IPC
viewtopic.php?f=13&t=13091
- fordsmax471
It's not completely dead, "only" the screen is black and all sync3 buttons have no function. It shows up when scanning for modules on the HS CAN and I can also scan for DTCs (none logged) and run the module reset. On the other side the module self test gives an error: "Vehicle conditions are incorrect".
- fordsmax471
what OBD adapter do you haveJensG wrote: Mon Jun 15, 2020 6:51 pmIt's not completely dead, "only" the screen is black and all sync3 buttons have no function. It shows up when scanning for modules on the HS CAN and I can also scan for DTCs (none logged) and run the module reset. On the other side the module self test gives an error: "Vehicle conditions are incorrect".
I've the elm327 with ms/hs-can switch and the faster els27.
I would like to get the beta version of the software if possible. I would Like to try the module update features.
phnahes
- Vehicle: Ford Focus MK3.5 - GDI_2.0L 2016 Flex Fuel
I would like teesting this!
Because I need reprogram my Ford Focus mk3.5 PAM module, for flank guard works...
mandelbloom
- Vehicle: ranger 2019
Is it possible to get 2.4 now? I upgraded my 19 Ford Ranger to 3.4 and wanted to upgrade the APIM unless that is not recomeneded?
Thanks!!
Thanks!!
Can I also sign up for 2.4 beta, please?
Are you still accepting new testers? I need to calibrate my APIM for it to be able to display radio logos and I don't want to pay a dealership to do it.
