Kicker subwoofer and 727-01-02
Re: Kicker subwoofer and 727-01-02
The xxx's in the first line are to be left alone as well.
James, MY MAN!
thank you, and everyone else on this thread, so much for your assistance. spelling it out in layman's terms so that a novice like me could figure it out.
the 727-01-02: 0088-B9xx-xxxx adds the low pass crossover and the system sounds sooooooo much better. it took a little bit of loading and tinkering to better understand how FORScan works. the sound quality has greatly improved and is at a point i feel is correct (given the limitation of a small amplifier and 8" woofer).
i was even able to add the Bambi mode successfully (fogs on with high beams).
i hate it took so long for me to be able to resolve, but very glad this forum exists for mods and tweaking.
mentzer814
- Vehicle: 2018 f150 3.5
So is It all good now was that in the acm config
it is good now. the "error fix" in 727-01-02 activates the built-in crossover in the ACM.
MarkPelszyk
- Vehicle: 2019 F-150
I installed the kicker sub n my 2019 xlt with 7 speakers. I used these FORScan 727-01-01 xxx8 xxxx xxxx - Auxiliary External Subwoofer
727-01-02 0088 B9 - Kicker/Subwoofer Selection "error" When I changed the value in 727-01-01 to xxx8 xxxx xxxx it made my ACM say that I’m using 6 speakers and not 7 speakers. The dash speaker does not work when I change the value to xxx8. When I have a xxx9 in place the center dash speaker works. Does the center speaker dash need to be disabled? forscan reading
- auxiliary external subwoofer: enabled
- engine noise enhancement: disabled
- kicker install: 6 speaker - kicker should be 7????
- mute radio: disabled
nightraven
- Vehicle: Ford Ecosport 1.5 Diesel
Please read through my post
https://www.forscan.org/forum/viewtopic ... 16&t=16150
I hope it helps you. You can try changing the Speaker Configuration option to "10 High Series Speakers with Subwoofer".
jdegiuli13
- Vehicle: 2022 Ford F150 Raptor
How can I get these changes needed!Crunchtime2k wrote: Tue Apr 21, 2020 12:11 pm I do have a fix for the weird muffled , muddy , low quality and low volume sound on the 19 and 20 B&0 systems.
It requires 3 changes if I remember to a few diff modules , acm and dsp , I will dig out my notes later today and help if needed still.
Can you post your data for acm and dsp modules also your trucks config , BO super crew or super cab
How does nightraven have all of those options available in his ACM config and I only get the basic 4 to select mute, engine noise, number of speakers. How do I get the flat EQ and all that other cool stuff? I just installed my kicker 8” factory sub on my 2019 XLT
Any luck here?jdegiuli13 wrote: Sun Mar 13, 2022 12:34 pmHow can I get these changes needed!Crunchtime2k wrote: Tue Apr 21, 2020 12:11 pm I do have a fix for the weird muffled , muddy , low quality and low volume sound on the 19 and 20 B&0 systems.
Any update on the equalizer settings?
japapoe wrote: Thu Jul 07, 2022 10:50 amAny luck here?jdegiuli13 wrote: Sun Mar 13, 2022 12:34 pmHow can I get these changes needed!Crunchtime2k wrote: Tue Apr 21, 2020 12:11 pm I do have a fix for the weird muffled , muddy , low quality and low volume sound on the 19 and 20 B&0 systems.
