Ecosport 2019 Blindspot/Cross Traffic
Barakeko
Vehicle: Ecosport, 1.0 Ecoboost/125, 2019
Post by Barakeko »
My car is Titanium without blind spot and cross traffic, i bought 2 used blind spot modules and mirrors after installing, they didn’t work and these errors appear:
SODR U3002:62-AB - Vehicle Identification Number
SODR B11D6:15-AB Driver display alert LED
SODL U3002:62-AB - Vehicle Identification Number
SODL B11D6:15-AB Driver display alert LED
i corrected VIN number in both modules and this error disappeared U3002:62-AB from both.
i added the as build data from another car to IPC, after enabling the blind spot & cross traffic on IPC, i've the following errors:
IPC U0533:56-08 Code: U0533 - Invalid Data Received From Side Obstacle Detection Control Module A
IPC U0534:56-08 Code: U0533 - Invalid Data Received From Side Obstacle Detection Control Module B
in PDM/DDM i changed the following and now when i start the car both mirrors Blindspot light open for 5 seconds and then turn off:
740-04-01 AA00 0019 0F to be AE00 0019 0F
741-04-01 A200 0019 08 to be A600 0019 08
still also having this error:
any solution?
Barakeko
Re: Ecosport 2019 Blindspot/Cross Traffic
Post by Barakeko »
any help?
chappers
Vehicle: Ford Mustang GT 2016
Post by chappers »
what vehicle are the BLIS modules from? have you copied a similar spec Ecosport as built data across to the whole module? also what about wiring was it prewired or have you added the wiring yourself?
i'm about to undertake this myself for the mustang there's quite a detailed thread here:
https://www.mustang6g.com/forums/thread ... ta.107623/
this may help.
