2.4.1 - APIM Firmware update doesn't work
kurek99
Vehicle: Fusion 2017 1.5 182
Re: 2.4.1 - APIM Firmware update doesn't work
Post by kurek99 »
During the APIM update and at 99% an error popped up and the update was interrupted and now the radio does not work. Can you save it somehow? pops up when loading firmware: Unable to read current firmware p \ n:
AHNA1711
Vehicle: 2017 Ford Explorer Limited 4dr SUV AWD (3.5L 6cyl)
Post by AHNA1711 »
2B-4G10 wrote: Sun Sep 13, 2020 4:13 pm Guys i updated ACM and APIM, first APIM, the sound system was still fine then, after that i updated the ACM to a version that was different than my version, but all was green, and i made sure what my version was, all of them, anyhow the update ruined sound, i updated them back to the original version, all of them, still nothing.
TL;DR
After ACM update Volume shows 0 only. Sound is so low. Coming from central console speaker only. Screen is Sync3 2018, but updated to CyanLabs V3.4
What i tried:
- Reverting versions to prior updates.
- Resetting Module.
- Clearing CEL codes.
UPDATE:
It was loading AB files 🤣💔 it's all fixed now !
Yes just load Factory AB to restore the sound after ACM update. This happened to me too :lol:
AHNA1711
Post by AHNA1711 »
kurek99 wrote: Fri Sep 18, 2020 6:41 pm During the APIM update and at 99% an error popped up and the update was interrupted and now the radio does not work. Can you save it somehow? pops up when loading firmware: Unable to read current firmware p \ n:
Did you take a picture of your original APIM Calibration files before you update it?
kurek99
Post by kurek99 »
I have a saved APIM configuration before the upgrade. Saved configuration before programming.
AHNA1711
Post by AHNA1711 »
kurek99 wrote: Fri Sep 18, 2020 7:12 pm I have a saved APIM configuration before the upgrade. Saved configuration before programming.
Use Forscan v2.4.0 to update the APIM calibration. Select custom firmware and upload the original files of your APIM then click update.
kurek99
Post by kurek99 »
Where can I download Forscan 2.4.0? someone can send an email to: kurek99@o2.pl
MoJo88
Vehicle: Mondeo Vignale 210ps 2017
Post by MoJo88 »
Doesn't 2.4.2 have this function?
kurek99
Post by kurek99 »
AHNA1711 wrote: Fri Sep 18, 2020 7:24 pm
Failed to. Same error. Used Forscan 2.4.0 20200309
kurek99
Post by kurek99 »
AHNA1711 wrote: Fri Sep 18, 2020 7:09 pm
I don't have a photo before updating
AHNA1711
Post by AHNA1711 »
Are you able to get your Hardware Number?
