Hello , i am using forscan with a wifi obd , when i try to enable something it tries to download a firmware but fails as the i am using a wifi obd ( so no internet ) so where can i download such file ?
P.S: "F1FT-14C097-AA.VBF" is the file i am looking after atm .
download firmware files offline
- fordsmax471
Re: download firmware files offline
unpack and copy
C:\Users\Documents\CalibrationFiles
richardc1983
- Vehicle: Ford Focus MK3.5 2.2 ST3
Do you put the zip file in or the actual file contained within?
The CalibrationFiles.zip file, if you downloaded the Forscan archive here http://forscan.org/download/CalibrationFiles.zip, must be extracted (unpacked) by the Windows Explorer built in file extractor or a third party extractor such as 7zip, into the C:\Users\{your user name}\Documents\, as this is where Forscan is going to go looking for them. The extractor should unzip and create the Calibration Files folder in your MY Documents Folder.
There should be 45 files in the \CalibrationFiles folder after extraction and the file names in the folder will end in .vbf and not .zip!
richardc1983
Yep I tried that and it just crashed and reset. I heard that Ford blocked access into the BCMii Central configuration screen.
sorry to bump an old thread but thank you for posting the files - i've been looking everywhere for the VBF file for Cruise Control, i'm going to try again this weekend and get it installed.
