Turbo values reset relearn n75?
Wod
Vehicle: Ford Fiesta 1.6 tdci
Post by Wod »
Hello, is it possible yet to reset the value for the turbo operation?
I know it supported on some models
I have the fiesta Tdci 1.6 I sent you some logs once before
Thank you
Re: Turbo values reset relearn n75?
Sorry, we are not aware for such a function for Fiesta 2006.
Wod
Post by Wod »
FORScan wrote:Sorry, we are not aware for such a function for Fiesta 2006.
Can I reset the Ecu by unplugging power for 30 minutes or is this a myth?
I am fitting the gt1544v vnt turbo in place of the td025.
Maybee I can use vnt % pid to set the turbo up if it needs adjusting on the rod?
I undersrand vnt should go to 100% before requested boost is met and then it reduces to stop overboost?thank you
