Airbag reset Focus 2008
gigen1979
Vehicle: Ford Focus
Post by gigen1979 »
Hi, I have a Ford Focus tdci 2008 with airbag light on.
Can I reset the airbag error with forscan?
Need modified elm with hs can switch to access airbag control module?
Re: Airbag reset Focus 2008
Yes, your vehicle should have RCM module on the MS-CAN bus, so you need an adapter with MS-CAN support.
gigen1979
Vehicle: Ford Focus
Post by gigen1979 »
Thank you!
The light go on after car crash, no airbag open.
Can I go off the airbag light with forscan or need ecu reprogramming?
it depends on DTC code. If it was a crash even, most likely DTC reset would not help to clear the error. Some vehicles have special service procedure for crash reset (not implemented in FORScan, though). Usually such a procedure can be ran not more than 5 times. Other vehicles have no such procedure.
