https://docs.google.com/document/d/1416 ... wnzIxRLp_8
No coding required very safe and easy. Just download forscan, get your 2 month free trial extended license and then you can select your theme from a drop down menu in the APIM. Pictures attached
I've seen people change the values of codes and mess up, this way is much cleaner and effective.
Drop down menu for theme selection will only work after you have downloaded the V3.0 update in the link above.
How to Change to Any Theme Permanently on Sync 3 2015-2018.5
- APIM.jpg (56.21 KiB) Viewed 11647 times
- APIM Theme.jpg (37.93 KiB) Viewed 11647 times
- Ford GT.jpg (60.46 KiB) Viewed 11647 times
musclesoh92467
- Vehicle: mustang v6 2016
Re: How to Change to Any Theme Permanently on Sync 3 2015-2018.5
I have updated to 3.4 can you tell me if the Ford performance cobra is on the drop down menu ? Thanks Eric
MasterSiep
- Vehicle: 2014 Ford S-Max 1.6 Platinum
It is. I have it. Am on 3.4.20828
Ford Mondeo MK5 2016 1.5L diesel - FORScan 2.4.3 - OBDLink EX - MacBook Pro with Windows 11 Pro (Dual Boot)
Ridemorestressless
- Vehicle: F150, 3.5eb, 2015, platinum
Hello, great post.
I have sync 3.4, and can't get the changes to do anything. Has anyone gotten 3.4 to change theme to the darker gray lincoln theme permanently?
The only way i can get it to change is in testing options through the head unit. When APIM changes are made and written whey don't do anything.
I am having the same issue. I can not get it to change theme.
