Enable cruise control on BA Falcon
gregc
Vehicle: BA Falcon 4 liter 6i 2003
Re: Enable cruise control on BA Falcon
Post by gregc »
Thanks f wolf
So you can only work with HIM BEM and IC on the BA falcons
Can’t get PCM and BCM which I would need to enable the cruise control
It looks like forscan might not be very good for our BAs
Is there a better program to work with using our obd equipment?
f-wolf
Vehicle: *** Ford ***
Post by f-wolf »
gregc wrote: Tue Mar 09, 2021 10:13 pm Thanks f wolf
Also have a red here ( 3rd post from the top ): http://www.fordmods.com/ba-bf-sx-sy-sca ... 10-20.html
It goes in to more details re ISO
And ...
viewtopic.php?t=2536&start=10
gregc
Post by gregc »
Thanks for all that f wolf
It looks like I have to go to the Ford dealer unless someone has an alternative in Brisbane maybe someone with Ford IDS
AFR
Vehicle: Falcon XR6T Sprint I6T 4000cc 370Kw
Post by AFR »
Give you a little tip if you have a VCMII or bosch equivalent adapter Go to motorcraftservices.com. Register as an US citizen. log in and pay for a 72 hr subscription. It can be tricky paying as you have to put in US detail . once you have subscription connect car via workshop and the last box will have IDS for 72 hrs. Only thing you cannot do is PATS programming. I update sync2 and 3 using this method but that's sync section which is different to IDS.
PSS change you IP location in google to a US state
robagars75
Vehicle: px2 wildtrack 2016
Post by robagars75 »
Hey guys I no this is a old post but has any one had any luck activating the cruise on the BA using for scan
