Hiya, can anyone help with this little problem, I have a 53 plate Mondeo (built Oct 2003) with the 5speed durashift semi-auto box in it.
I've read in the manual that i need diagnostic equipment to check the oil level, is it possible to do the fluid / oil level test with this software?
Or, can I just drain and refill it?
Thanks Guys
Durashift (5sp) fluid / oil level test
littlekev1973
Re: Durashift (5sp) fluid / oil level test
Job sorted!
There was no need to find the fill level, I drained it off - there was only 3ltr in it.
It's now topped up with just shy of 8lts of top grade auto gearbox oil and changes gear properly.
stimpy88
- Vehicle: Ford Mondeo Mk5 - Diesel 2.0, 150, 2017
Glad you got it sorted, but it sounds strange to me that it lost so much oil in the first place.
