I would like to download Beta 2.4.x. I am using OBDLink EX with the latest firmware on it. I also bought the FORScan Lifelong Extended License
could you pls. also send me a link to the beta version for programming? Thanks
marius3k
- Vehicle: Focus fyda 2000, C-max g6db 2.0/100kw 2005
May I have a link to 2.4.X.
Tia
Tia
Please send me a link or PM to Beta version download.
Thx
Thx
bikerlife82
- Vehicle: Ford Focus mk3.5/ 1.5tdci 120cv/2015
Re: Test della funzione di aggiornamento del firmware per i moduli Ford
updating pcm bcm and abs in the ford focus my2015 deletes stored data such as key codes or updates the firmware without deleting anything?
benson2907
I‘ve got the same issue. I only updated the IPC and lost the drive modes.antani wrote: Tue Dec 15, 2020 9:01 pm Hi!
I've flashed the AWD, IPC and BdyCM modules for my Focus RS MK3, all went well during the flashing but only when driving the car I've realized that the drive mode can't be changed as there are none when I press the hardware button on the central console.
Any idea on how I could solve that issue please?
Did you find a solution?
Thanks in advance.
Ben
Hello. I would like to test version 2.4.0 kuga 2.0
I have a none functioning fuel gauge and was told a firmware of my ipc my fix the problem. Can someone send me a Link to the latest version of Forscan . I have a lic. And really nothing to lose since I'm trying to upgrade to the 8inch witch is the cluster with the problem.
Hello, does anyone have the strategy file BT4T-14C026-BP and the calibration file BT4T-14C088-BL? I tried updating my 2011 Edge IPC from BT4T-10849-GM to GV but it failed and I need to revert.
