Changing radio frequency Ford Fusion 2013
Mayacine
Vehicle: ford fiesta Gazoline, automatic 2014
Re: Changing radio frequency Ford Fusion 2013
Post by Mayacine »
hELLO
I HAVE FIESTA 2014, WHAT IS FRANCE COUNTRY CODE?
rioachim
Vehicle: Focus, 1.6 100CP, 2005
Post by rioachim »
deleted post
rioachim
Post by rioachim »
Hello. Could you please tell me what assembly version is offered by IDS for Fusion model? Or for any US car for which a conversion is needed, actually. I would like to check the vbf files by comparing with the european offered update files. Thank you
stundentas wrote: Sun Jun 24, 2018 8:03 pm
CeresPL wrote: Thu Oct 26, 2017 12:54 pm Hello!
Please help me:
how to change frequency from USA to EU in radio.
Thanks for help.
727-04-01 x*xx xxxx xxxx Tuner Region: 0=NA (North America), 1=GCC, 2=Japan, 3=Europe, 4=Asia Pacific
727-04-01 xxx* xxxx xxxx SDARS Region: 0=unconfigured, 1=U.S., 2=CANADA, 3=no content
727-04-01 xxxx x*xx xxxx SDARS Data Services: 0=unconfigured, 1=Data Services, 2=no Data Services
727-04-01 xxxx xx** **xx Country Code: 5553=U.S., 4341=CANADA
After coding : update ACM to newest sofware version
Update you can do with ford IDS
CeresPL
Vehicle: Mondeo/Fusion 2013
Post by CeresPL »
pawelbeczkowski
Vehicle: Explorer,2014,3.5L,
Post by pawelbeczkowski »
Hi .did you manage to change the code on the radio to have frequency and rds
omar302
Post by omar302 »
From my experience, if the RDS didn't work after changing the tuner for frequencies, there is no solution by ForScan. Few people have reported that changing the ACM firmware can fix it, but it is not confirmed and it is not known which firmware is required.
Vilcinjsh
Vehicle: Ford Explorer, 3.5l V6, 2016
Post by Vilcinjsh »
Regarding country codes. As I understand it is simply a country two-letter name converted to HEX, therefore US is 5553, 4445 is DE (Germany) etc.
I used a simple txt to HEX converter online, hope it works!
Rdecode
Vehicle: 2014 Ford Escape 2.0L EcoBoost 4x4
Post by Rdecode »
2014 ford Escape 2.0L 4WD, SYNC1
I have changed in ACM value "*" from "0" (US) to "3" (EU) to have "even" frequencies
RDS is added, it also search channels but showing still only "odd" frequencies in the list of found radio stations, but it is possible to tune to "even" frequency manually...
How to fix automatic search and list of "even" stations?
Javitam
Vehicle: Ford mustang 2015
Post by Javitam »
Hi, I have a 2015 mustang with sync 3.4 that I bought in the USA but moved to Europe and have the same problem. Tried Forscan , but cannot find the ACM module. Anybody can help , please?
yaras6
Vehicle: Ford Fusion 1.5 Ecoboost 2018
Post by yaras6 »
Any solution for not working RDS? When region is set to US, RDS works as expected. Unfortunately, after region and country code change to EU/PL, RDS stops working, which is strange.
Should I change something more? May be somebody have both working, can paste full configuration for 727-04-01?
Can I find somewhere a Forscan CheetSheet for Ford Fusion?
Thanks in advance :D
