Mazda2 not found
simonvf400
Mazda2 not found
Post by simonvf400 »
I am trying to connect to my 2003 Mazda 2 1.6 petrol UK spec.
Forscan comes up with unsupported vehicle.
Here is my lo file.
13:43:58.838 [GUI Main Window] FORScan v2.2.7 beta started
13:43:58.869 [Ford Vehicle] OBDVehicle Thread started with id 208
13:43:58.872 [Ford Vehicle] Trying COM4, device \Device\Serial2
13:43:58.910 [Comm Adapter] Adapter Thread started with id 22C
13:43:58.928 [Comm Adapter] Profiling: 18 ms
13:43:58.945 [Comm Adapter] Profiling: 17 ms
13:43:58.945 [Comm Adapter] ELM327 detected!
13:43:58.950 [Comm Adapter] Profiling: 5 ms
13:43:58.950 [Ford Vehicle] Adapter found on COM4, 38400 bps, move forward with it
13:43:58.960 [Comm Adapter] I'm finishing
13:43:58.970 [ELM327 Adapter] Adapter Thread started with id 210
13:43:58.975 [ELM327 Adapter] Profiling: 5 ms
13:43:58.993 [ELM327 Adapter] Profiling: 18 ms
13:43:59.000 [ELM327 Adapter] Profiling: 7 ms
13:43:59.005 [ELM327 Adapter] Profiling: 5 ms
13:43:59.010 [ELM327 Adapter] Profiling: 5 ms
13:43:59.015 [ELM327 Adapter] Profiling: 5 ms
13:43:59.020 [ELM327 Adapter] Profiling: 5 ms
13:43:59.026 [ELM327 Adapter] Profiling: 6 ms
13:43:59.031 [ELM327 Adapter] Profiling: 5 ms
13:43:59.036 [ELM327 Adapter] Profiling: 5 ms
13:43:59.041 [ELM327 Adapter] Profiling: 5 ms
13:43:59.047 [ELM327 Adapter] Profiling: 6 ms
13:43:59.053 [ELM327 Adapter] Profiling: 6 ms
13:43:59.053 [Ford Vehicle] Checking ping delay
13:43:59.070 [ELM327 Adapter] Profiling: 17 ms
13:43:59.087 [ELM327 Adapter] Profiling: 17 ms
13:43:59.104 [ELM327 Adapter] Profiling: 17 ms
13:43:59.110 [ELM327 Adapter] Profiling: 6 ms
13:43:59.115 [ELM327 Adapter] Profiling: 5 ms
13:43:59.120 [ELM327 Adapter] Profiling: 5 ms
13:43:59.125 [ELM327 Adapter] Profiling: 5 ms
13:43:59.142 [ELM327 Adapter] Profiling: 17 ms
13:43:59.158 [ELM327 Adapter] Profiling: 16 ms
13:43:59.167 [ELM327 Adapter] Profiling: 9 ms
13:43:59.174 [ELM327 Adapter] Profiling: 7 ms
13:43:59.182 [ELM327 Adapter] Profiling: 8 ms
13:43:59.193 [ELM327 Adapter] Profiling: 11 ms
13:43:59.205 [ELM327 Adapter] Profiling: 12 ms
13:43:59.214 [ELM327 Adapter] Profiling: 9 ms
13:43:59.224 [ELM327 Adapter] Profiling: 10 ms
13:43:59.224 [Ford Vehicle] Found PCM type: 0x122
13:43:59.232 [ELM327 Adapter] Profiling: 8 ms
13:43:59.242 [ELM327 Adapter] Profiling: 10 ms
13:43:59.252 [ELM327 Adapter] Profiling: 10 ms
13:43:59.264 [ELM327 Adapter] Profiling: 12 ms
13:43:59.323 [ELM327 Adapter] Profiling: 59 ms
13:43:59.383 [ELM327 Adapter] Profiling: 60 ms
13:43:59.443 [ELM327 Adapter] Profiling: 60 ms
13:44:04.460 [ELM327 Adapter] Profiling: 17 ms
13:44:04.518 [ELM327 Adapter] Profiling: 58 ms
13:44:04.576 [ELM327 Adapter] Profiling: 58 ms
13:44:04.634 [ELM327 Adapter] Profiling: 58 ms
13:44:09.651 [ELM327 Adapter] Profiling: 17 ms
13:44:09.663 [ELM327 Adapter] Profiling: 12 ms
13:44:09.672 [ELM327 Adapter] Profiling: 9 ms
13:44:14.689 [ELM327 Adapter] Profiling: 17 ms
13:44:14.749 [ELM327 Adapter] Profiling: 60 ms
13:44:14.809 [ELM327 Adapter] Profiling: 60 ms
13:44:14.869 [ELM327 Adapter] Profiling: 60 ms
13:44:14.929 [ELM327 Adapter] Profiling: 60 ms
13:44:14.989 [ELM327 Adapter] Profiling: 60 ms
13:44:15.046 [ELM327 Adapter] Profiling: 57 ms
13:44:15.103 [ELM327 Adapter] Profiling: 57 ms
13:44:15.161 [ELM327 Adapter] Profiling: 58 ms
13:44:15.172 [ELM327 Adapter] Profiling: 11 ms
13:44:15.233 [ELM327 Adapter] Profiling: 61 ms
13:44:15.242 [ELM327 Adapter] Profiling: 9 ms
13:44:15.252 [ELM327 Adapter] Profiling: 10 ms
13:44:15.312 [ELM327 Adapter] Profiling: 60 ms
13:44:15.322 [ELM327 Adapter] Profiling: 10 ms
13:44:15.332 [ELM327 Adapter] Profiling: 10 ms
13:44:15.393 [ELM327 Adapter] Profiling: 61 ms
13:44:15.402 [ELM327 Adapter] Profiling: 9 ms
13:44:15.402 [Ford Vehicle] Failed to find vehicle identification information
13:44:18.420 [ELM327 Adapter] Profiling: 17 ms
13:44:21.161 [ELM327 Adapter] I'm finishing
13:44:21.178 [Ford Vehicle] Thread stopped
Any ideas?
Re: Mazda2 not found
It may be an adapter problem, need second log file to check. Answered via PM
simonvf400
PM sent
Thanks for the logs. As answered via PM, the problem is with adapter. It is not a fully compatible with original ELM327. OBDII software should work with it. But FORScan and any other software that uses service protocols will never work with it. Sorry.
Here are some discussions about bad clones:
http://forscan.org/forum/viewtopic.php?f=4&t=1575
simonvf400
I have looked at the link but I am not sure how to use terminal commands.Please could someone give me some basic instuctions on how to do this.Where do I find terminal?
Thanks for the help.
fred08155
Post by fred08155 »
You can use STNterm for easier usage.
http://forscan.org/forum/viewtopic.php? ... nterm#p720
Or any other terminal application of your choice. You just have to connect to the right Com-Port.
http://realterm.sourceforge.net/
https://ttssh2.osdn.jp/index.html.en
http://www.putty.org/
http://www.der-hammer.info/terminal/
simonvf400
Thanks for the links I will try them.
