Hi Guys,
I checked my cars error codes (Ford Mondeo MK4 (2007-2011) as I had the airbag light on! When I checked the realtime data, it seemed that although the error said B1128 - the driver side curtain airbag has a 'circuit open', If I view the live PID data though, Front Passenger Airbag Curtain Resistance is 10 and Front Driver Airbag Current Resistance is 3.
I think the software may just have the PID's the wrong way, so wonder if anyone else has seen this, or can confirm it or say otherwise?
Airbag Resistance PID wrong FORD
Re: Airbag Resistance PID wrong FORD
Can you please post here full DTC description provided by FORScan (interested in DTC status and subcode (guess it is 'open circuit', but just in case), and also CSV file with all resistance PIDs readings (or screenshot - up to your convenience)?
To save DTC text, select DTC and click on the diskette button, select a file. To save PID live streaming as CSV, click on diskette button and select *.CSV in the file selection dialog.
