Performance fix of china ELM327 WiFi adapter
MaXyM
Re: Performance fix of china ELM327 WiFi adapter
Post by MaXyM »
hello
I recently bought VGate iCar3. I tried to access AP configuration page entering admin/admn credentials. After that I got: 404 error (no page found). I cannot even open login page again.
Does it mean access to configuration is blocked?
with regards
If you disconnect and connect the adapter, and try again, does it show login page again?
MaXyM
Post by MaXyM »
Yes. It does.
william
Post by william »
when i got my icar2 i tried to access the page and failed, i contacted the seller and he said it was not possible to access.
08 mk4 mondeo 2.0 140 bhp
MaXyM wrote:Yes. It does.
It means the Web service is available, but the page is deleted or renamed. You may try to call some pages like index.htm, login.htm, admin.htm and so on, although there is no much chance it will work.
No idea why the adapter developers close access to the control panel, it doesn't seem reasonable.
ViRuS2k
Post by ViRuS2k »
for WPA2 without webinterface:
http://www.v2kn.com/2016/04/obd2-wifi-a ... absichern/
ViRuS2k wrote: for WPA2 without webinterface:
Thanks for the link, so users with WiFi iCar/V-Link may try this credentials to access control panel:
URL: http://192.168.0.10/iweb.html
User: admin
Password: admin
wh-7
Vehicle: Ford F250 King Ranch
Post by wh-7 »
I have the china ELM, just got it a couple of days ago from Amazon.
When I web in to the device I get a blank screen. Doesn't prompt for user or password. Connects but blank.
Anyone else encounter this issue?
wh-7
Post by wh-7 »
Never mind, I read through all the posts and see that I just bought a POS. :(
Gasman
Vehicle: Transit fwd 2.2 85 2008
Post by Gasman »
I’ve got the elm 327 v1.5 Wi-fi and it connects to FORScan then won’t load vehicle details , even bought another elm unit to see if that would identify vehicle (which is a 2007 ford transit t280) , annoying as I had a previous elm 327 which I lost a while back and these recent two replacements both suffer same issue . Any ideas guys?
