Firmware download from Ford site doesn't work anymore
borisdolinaNEW
Vehicle: ford focus 3, 1.6 Duratec, 125Hp, 2011
Re: Firmware download from Ford site doesn't work anymore
Post by borisdolinaNEW »
Could you help me with the files for APIM?
GB5T-14G376-AA.VBF
GB5T-14G374-AF.VBF
GB5T-14G375-BA.VBF
GB5T-14G376-AA.VBF
GB5T-14G379-AA
GB5T-14G379-BA
Try to recover my APIM after failed update(
Thanks!
borisdolinaNEW wrote: Mon Oct 18, 2021 10:29 am Could you help me with the files for APIM?
GB5T-14G376-AA.VBF
GB5T-14G374-AF.VBF
GB5T-14G375-BA.VBF
GB5T-14G376-AA.VBF
GB5T-14G379-AA
GB5T-14G379-BA
Thanks!
https://www.fordtechservice.dealerconne ... roduct=IDS
borisdolinaNEW
Tried, but nothing can't be found on DSFM site(
More – one of the file is broken from the ford site – from Forscan support is working
borisdolinaNEW
could you help me one more time for download
DS-F1FT-19H406-AE
ECU Core Assembly Number" Data="F1FT-14F403-AE
ECU Delivery Assembly Number" Data="F1FT-19H406-AH
ECU Software #2 Part Number" Data="F1FT-14F397-BE
ECU Calibration Data #1 Number" Data="F1FT-14F398-AG
??? need to recovery my IPMA (died)
Thank you )
mustafasinaokur
Vehicle: 2002 ford focus 1.8 tdci
Post by mustafasinaokur »
someone tell me my ford fiesta 2013 pscm module is dead. I need vbf and sbl files to remove can help?
rootshell
Vehicle: Ford f150 2015
Post by rootshell »
MoJo88 wrote: Thu Sep 17, 2020 9:32 am https://easyupload.io/zu4ja0
could you pls reupload files GB5T-14G375-GA
MKK777
Vehicle: Ford S-Max 2.0L Powershift WA6
Post by MKK777 »
good morning I desperately need help as I have DDM dead, I also asked for help from forscan assistance! nothing nothing ... the criminal file is: 9G9T 14C067 AA .VBF if someone has a couple or maybe can show me the way I would be happy
MKK777
Post by MKK777 »
:arrow: :arrow:
Michal1985
Vehicle: Focus, Dv10 2.0 TDCi 103 kW, 2011
Post by Michal1985 »
Hello gentlemen,
would anyone have these files available for the IPC ST before the facelift?
BM5T-14C025-BE
BM5T-14C026-BT
BM5T-14C026-CU
CM5T-14C026-LB
CM5T-14C318-AC
Thank you in advance
Spornyi
Vehicle: Fusion 2.0 EcoBoost 2015
Post by Spornyi »
I found only theses files maybe they will help you.
BM5T-14C025-BE.ZIP
(13.14 KiB) Downloaded 74 times
CM5T-14C318-AC.ZIP
(14.02 KiB) Downloaded 67 times
