2.4.4 - Cannot read BCMii
smartguy69
Vehicle: Kuga Titanium,2 litre diesel, 150PS, 2015
Re: 2.4.4 - Cannot read BCMii
Post by smartguy69 »
I am going to stick with V2.3.41 for now as it works for me. I never installed V2.3.42.
Looks like @admin need to take a look and see why V2.3.43 and the 2.4.4 have an issue accessing BCM Main Configuration and why the SBL bootloader screen doesn't populate.
cezarg1410
Vehicle: Focus mk2 2.0 TDCI 2009
Post by cezarg1410 »
It is well known issue.
I wrote an email to support and They send nie very quickly version 2.4.5 and there it works fine.
srahul0809
Vehicle: Ford Focus ST Line 2017 1.0 ecoboost
Post by srahul0809 »
I have the same issue. I am using 2.4.43 release. Is there anyway I can get 2.4.5?
ladadens1
Vehicle: ford europe germany
Post by ladadens1 »
hi! i have ford cmax bcm problem. i read orig bcm some weeks ago.
now i install new (2.3.43) and cant read old or new bcm.so its an big bug in software
it read 5% then shows contact developper.so im not the only one.
have full leicense but can do nothing :(
ladadens1
Post by ladadens1 »
would be nice when support can send me to ladadens1@aol.com
big thx
djdekl
Vehicle: Focus MK3.5 1.5 134kW
Post by djdekl »
Hello, I have a ForDiag USB cable adapter + Forscan 2.3.43 + Ford Focus MK3.5 - BCMI primare configuration edit - when started, the process is abort.
Older versions of Forscan 2.3.39 works fine :? Please help
I use: Forscan, IDS, FDRS, UCDS, Fordiag
Mark12
Vehicle: 2014 Ford Focus MK3 Titanium 1.0 EcoBoost
Post by Mark12 »
Hello guys, I encountered the same issue with FORScan 2.4.4 and after un-installing and re-installing an older version I had the exact same issue present.
What resolved this error for me was;
1. Un-install FORScan.
2. In Windows go to folder options and check the box marked ' Show hidden files, folders and drives '
3. Navigate to on your main drive ' C:\Users\***Your user name here**\AppData\Roaming '
4. You should find a ' FORScan ' folder.
5. Delete this folder or just rename it if you like.
6. Re-install FORScan and you should now be able to read the BCMii with no issues.
Hope this helps someone out.
laurentiu7
Vehicle: Focus MK3 Ecoboost 150 HP
Post by laurentiu7 »
Can't access BCM Main Configuration, message "Service procedure interrupted " ,when started, the process is abort.
I have a USB cable adapter + Forscan 2.3.43.Older versions of Forscan 2.3.XX works fine.
It seems it's a known issue.
I wrote an email to support and they send me 2.3.44.test20211107 version until official 2.3.44 release has been issued. Hope it will work, I will test later and came back.
MduButh
Vehicle: Ford Kuga, 2.0 TDCi Titanium, 2014
Post by MduButh »
Hi All
Anyone who has finally come right with 2.3.43 issue of BCMii not readable? please share your work around if any.
Takiry
Vehicle: Ford Fiesta, 1.0 mHEV 125PS, 2022
Post by Takiry »
Hello, I also had the problem with version 2.3.43
I wrote to support and they gave me 2.3.44TEST. Here you can read out without any problems. However, there is then another error when writing.
I use an ELM327 HS / MS
As has already been written here several times, it is a ForScan problem. Just use an old version. I tested 2.3.41 and 2.3.39. Both work fine.
regards
Takiry
