tire pressure monitoring system (tpms)
dusty42087
Vehicle: ford,5.4 2004
Post by dusty42087 »
how do you turn off the tpms in 2010 lincoin mkz , 2004 expedition and a 2008 f150 :?:
Re: tire pressure monitoring system (tpms)
Post by tractmec »
Hello dusty
In the 04 expedition there should be a line in the Instrument cluster module configuration that can be enabled to turn on or off TPMS or a line to enable as not equipped.
That is how it is done in my 03 Expedition. In my case it was not equipped as the module harness was missing the module.
Could not comment as to the others for sure but as the TPMS warning is usually monitored in the instrument Cluster message center it should be similar?
LaForge
Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
Post by LaForge »
I guess it too.
In Mustang 2006 there is also tpms function controlled by ipc module.
Best regards
Karsten
Changed on my 2011 Focus:
jemery.wa
Vehicle: 2004 Lincoln Navigator
Post by jemery.wa »
just did it in my 04 Navigator, I used the as built data from my 03 Navi that didn't come with TPMS, the ICM asbuilt line is 60-01 9000 9200 FF82.
Thesavo
Vehicle: Escape 08 3.0
Post by Thesavo »
So I have a question along the same line.
I have an 03 Eddie bauer expedition with as-built ICM
60-01 9000 9800 FF88.
Should I just change the second block from 9800 > 9200?
Post by tractmec »
Hi Thesavo
In my case it was changing the 2 in 9200 to an E but I cant remember if that disabled the warning or gave a "TPMS Turned Off" warning in the message center on startup. I have seen some asbulits listed as A in that position
Mine had a non asbuilt option in IC configuration that had TPMS listed and had the options to "Enable", "Disable" and Not Equipped that could be written and saved.
Thesavo
Post by Thesavo »
Interesting. I think the position in that block is the one to change. From what I remember, the last block is a checksum that forscan updates naturally.
Do you think an 04 with the follow blocks get changed like so?
60-01 9000 1800 FF08 tpms enabled.
Changes to
60-01 9000 1200 FFxx (xx) being the generated checksum?
Post by tractmec »
Hi
Yes the second number in the second block is the one to change. What I posted in my reply was what I found in my 03 Eddie Bauer.
The 04's may be different depending on build date. The last digits are a check sum and should calculate automatically correct if the correct change is made in the block 2 second digit.
My IC configuration had a non asbuilt section for TPMS that opened to three choices, Enabled, Disabled or Not Equipped and I chose not Equipped and clicked write. The procedure completed and the TPMS fault warning went away! If I chose disabled and wrote it, then the message center would flash up TPMS Turned Off on start up and go away until the next start up.
This was done a year ago and I do not remember which change on the second digit in block 2 of the asbuilt configuration did what. The Second digit change to E set the IC message center to TPMS Not Equipped as that was what it left the factory with according to my AsB file. Somebody before me was playing around and had enabled it and the fault warning was there because this EB did not leave the factory with a TPMS module.
Backing up the original setting is always a good Idea! It saves a lot hair pulling!
Thesavo
Post by Thesavo »
Thank you all. This helped. I don't have access to a Gen 2 expedition anymore. However, this helped out a user on expedition forum for their 2004 Expedition.
From what I gather this is what is required.
Leave the TPMS DA-01 as-builts alone. If you don't have anything but beltminder in the non - asbuilt IC Module, look for the IC Module as-built line below.
60-01 xxxx x#xxx xxxx
x8xx - TPMS Enabled
x2xx - TPMS Disabled?
xAxx -?
xExx - TPMS not equipped?
pseudeep
Vehicle: 2004 Lincoln Navigator 4WD 5.4L
Post by pseudeep »
Thesavo wrote: Sat Feb 08, 2020 2:15 pm So I have a question along the same line.
