service procedure has been interrupted
M.R.F.O.R.D
Vehicle: 2021 Ford F150 2.7
Post by M.R.F.O.R.D »
I have a 2021 F150. When I try to run the PCM Module relearn I get a message service procedure has been interrupted (change the tires size). I was told on a few forums that there's a new version that fixes this issue?
Exo_Strike
Vehicle: F150 FX4 3.5 Ecoboost 2014
Re: service procedure has been interrupted
Post by Exo_Strike »
I have the same issue on 2021 Navigator and 2021 Bronco.
I dont tried the last build on F150 2021, but i know a earlier test build (FORScanSetup2.3.40.test20210322) works on F150 2021, i did it before.
cwkd9
Vehicle: 2021 Ford Bronco
Post by cwkd9 »
I had the same issue and had to download and reinstall the firmware again, then it worked.
https://www.obdlink.com/support/ex/
trmoody
Vehicle: 2017 Ford Super Duty w/ 6.7L Powerstroke
Post by trmoody »
Did you already have the latest version of FORScan? I'm having the same problem and have the latest version (2.3.43). Did you delete this version and just reload it and everything was fine or did you upgrade to this version? This is driving me nuts.
:idea:
aspect
Vehicle: Maverick, Ecoboost 2.0t, 2022
Post by aspect »
I'm having the same issue with 2022 maverick...are there any more up to date versions that may solve the issue?
Thanks!
