VBF File Editor
- LaForge
- Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
- Contact:
Re: VBF File Editor
Hi there.
After several Testruns with VBF-Editor 2.2 I can say: It´s amazing!
You can export the bin Part to Intel HEX format and rewrite it with your Notepad Application.
You can im/export Headers and rewrite them in Notepad too.
Then create new File and import Header, Import Bin Part and save the result as VBF.
Flash it, it´s still works great. Tested with my IPMA Firmware.
If you know something about Intel Hex files you can rewrite the address field to set the firmware to new ecu address.
But until now it´s regrettably still does not work for me, because I try to change generation of Software from BM5T to F1FT
Example:
IPMA Focus 2013 BM5T-19H406-AG
Software Address 0x00020000
IPMA Focus 2016 F1FT-19H406-AH (camera looks similar to BM5T)
Software Address 0x00010000
so I have changed it to 20000 but it cannot be flashed. Error still occours.
Tried it with BM5T- Export Bin, export Header
Create new File
Import Header, import Bin
rewrite
Flash!
Works!
Fine!
Best regards
Karsten
Example:
Create new File
rewrite
Flash!
Works!
Fine!
Best regards
Karsten
Changed on my 2011 Focus:
Re: VBF File Editor
757093327@qq.COM
thank you
thank you
Re: VBF File Editor
ynr93@163.conPlease send me a copy, thank you!
ggrui59216
- Vehicle: focus RS Red 2.3T ECOBOSST 4WD
Re: VBF File Editor
Hello, thank you for sharing, this is my email
ggrui59216@126.com
ggrui59216@126.com
kiler-1977
- Vehicle: Ford Fusion phev 2017
Re: VBF File Editor
Hello, I am looking for a vbf converter 3.2 or newer. Someone help?
garymarlin
- Vehicle: Focus DW10C 140PS 2013
Re: VBF File Editor
Did anybody try to flash PCM Strategy file modified using VBF file editor? Any success?
guangzhouhuakai
- Vehicle: ford F550 7.3L 2020
Dragunov
- Vehicle: Ford Mondeo MK5 Titanium 2.0TDCi 150HP
Re: VBF File Editor
Purpose of such an editor?
Kellerleiche
- Vehicle: Ford Focus Mk3, 1.6l ECOBoost, manual
Re: VBF File Editor
Hello, could you please PM the VBF tool application to me?
