Ford Focus MK4 Battery
Donny
Vehicle: Focus 1.6 Tdci 201071QP67
Re: Ford Focus MK4 Battery Type Config BCM
Post by Donny »
To confirm what @Andural said about the BCM version, mine was updated in May this year when I was getting some unrelated warranty work done and it is exactly the same as @Andural's, so it was the latest version in May.
My TCU version is completely different from your ones, but I'm in the UK so there must be different versions for different countries :?:
With my car the TCU is updated automatically if I have Connectivity settings enabled
spender2611
Vehicle: Ford Focus MK4 1.0 125PS 2019
Post by spender2611 »
Yes I have to update my BCM.. That will maybe help..
After a couple of hours rest i tested again..
SoC dropped to 67%, showed in forscan. The over 90% werent real. Thats correct.
My batterytester showed me a different SoC 79%. So everything makes no sense at all.
Screenshot_20221015-232214_FORScan Lite.jpg (339.56 KiB) Viewed 2079 times
Ford Focus MK4 ST-Line 2019 Turnier
Donny
Post by Donny »
I don't understand it either. I don't use my car enough and my SOC in FORScan is normally between 50 and low 60%, but if I measure the Voltage across my Battery after fully resting the car it is normally 12.45 to 12.5 like your one, which should be about 70 or 80% :?:
Apart from Stop/Start only working twice this year, which I'm glad about because I saves my switching it off, I have not had anything else disabled because of low Battery charge.
My BCM update was for something else but it has not made any difference to my SOC. My PCM, TCU,ACM,APIM were also updated at that time.
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley »
On my 2016 the SOC is only accurately calculated when the vehicle sits overnight. SOC numbers change in real time while I'm driving, but the BCM needs a long period with no load to see how much the battery voltage drops. The voltage drop is used to calculate SOC.
spender2611
I have tried today to update the BCM firmware to the latest one. It unfortunately didnt work. The flashing went through without any problem and firmware was installed to the version Andural has,
But I had DTCs and flashing interior light which didnt went away. So I had to flash back to the old factory firmware. No more flashing but no update too.
spender2611
@Anduril
Ive sent you a private message :)
spender2611
My BCM is running now, thanks to ForScan and the Supportteam on the latest BJC Version.
I also have the latest CB Version of the BMS installed.
Last step will be the new battery. Now it has to be working..
stefcio007
Vehicle: Ford Focus 2020.25 Wagon
Post by stefcio007 »
My config was:
Varta 52Ah 500CCA T5 Case
This DID NOT match the actual battery and start stop rarely worked even after giving the battery a good charge.
I changed to:
Varta 70Ah 600CCA H6 Case (actual battery installed from factory)
My start-stop works everyday now.
I changed both settings in BdyCM Module:
Battery Type Factory
Battery Type Normal
I did not change Battery Type which is set to Flooded. The battery is an EFB so it's close enough.
Focus 2020.25 ST-Line 1.5L Wagon
Anduril
Vehicle: Ford Focus Active X
Post by Anduril »
How long (since type change) does it work?
stefcio007
Do you mean how long it keeps the engine off after stopping?
It depends on many factors such as engine temp and if heating/cooling is on.
If I turn heating/cooling off it says off for maybe 5 minutes when sitting at the lights, very long time now.
