official utility for change baudrate vlinker fs
http://www.jinxusolu.com/filedownload/94533
Vlinker FS Baudrate
scorpionul22
- Vehicle: Ford Focus MK3 RS
Re: Vlinker FS Baudrate
vLinkerFSBaudrate requires firmware higher than vLinker_FS_v2.2.91.beta1 to use.
If the firmware is lower than this version, restart the device after modifying the baud rate, the baud rate will return to the factory setting of 115200bps.
Firmware 2.2.91 beta2 is online
See : https://forscan.org/forum/viewtopic.php?f=4&t=21163
If you can´t fix it - don´t break it
