Keithmac
Post by Keithmac »
NP71 wrote: Tue Dec 06, 2022 2:27 pm Hello,
I have a problem with my Powershift 6DCT450 on my Mondeo mk4 2013. 5000km after changing the oil and filter it worked normally. Then it started shaking when changing gears or drastically changing revs because it shifted into the wrong gear, especially between third and fourth gear. Then it goes to Transmission limited mode. After resetting the module and clutch system and gear selector, by Forscan, it works perfectly but only for one day and then it starts again with the same problem.
The repairmen at the local garages immediately say without any consideration that the plastics, springs and everything else are broken and that everything must be changed, and the authorized servicemen only need to replace the entire transmission without repairing the old one.
To me, it is indicative that after the reset everything is fine and only after a day it goes back to the old way. In my opinion, this indicates that the problem is in something else and not in the mechanical part.
Does anyone have a similar experience?
The design is that poor that first thing to check is clutch pack, which is gearbox out job.
1000's have failed.
