Transit 2017 parameter reset
ledarka
Vehicle: Fiesta 1.4D 2004
Post by ledarka »
Hi
Is it possible to do parameter reset with this software on Ford Transit 2017 after BCM replacement?
I have 1 year extended license and cheap old ELM USB adapter that maybe must replace as I have errors to switch MS/HS CAN and not work properly
I found BCM reset and PCM reset but I can't see option parameter reset. Where must be this function?
Re: Transit 2017 parameter reset
Read all of this topic and see if it helps.
https://forscan.org/forum/viewtopic.php?t=20912
Get the OBDLink MX + or OBDLink EX and throw that other garbage away.
No communications = no connection.
