American 6.0L V8 Diesel cylinder balance/injector test
PrIsMaTiSm
Vehicle: Super Duty, 6.0 F350, 2005
Re: American 6.0L V8 Diesel cylinder balance/injector test
Post by PrIsMaTiSm »
I appreciate you at least recognizing this forum topic and addressing it. I will have to move away from FORscan for the moment. Hopefully you guys get the opportunity to get such a great feature operational soon.
izzy2004
Vehicle: F-350, Diesel 6.0, dyno 614, 2006
Post by izzy2004 »
Forscan typical sees devices like ELM which only use CAN bus which isnt capable of doing those things. To get the cylinder balance test or relative compression you need an adapter that does J2534 such as a VCM2 but if you have that device you would be using Ford IDS to do those tests anyway. Regardless though its very impressive what forscan manages to be able to access and use just with the CAN bus alone.
Long story short if you want to be able to get the power balance test and relative compression test as well as programming abilities go buy a VCM 2 clone that has 2 boards. Costs about 200 bucks. GL
ScottKrieger
Vehicle: 2003 Ford Excursion 6.0 Powerstroke Diesel engine
Post by ScottKrieger »
Thanks GL andy links to a suitable unit you reference with 2 boards? Can PM me if needed. I'm still chasing my tail on this one!
poolshark28
Vehicle: 2016 Ford Focus
Post by poolshark28 »
FORScan wrote: Fri Mar 31, 2023 8:11 am We are sorry, but at this moment FORScan doesn't implement the Ford Cylinder Contribution/Power Balance test. This is quite complex graphical test that requires fast adapter (ELM327 will not work, at least not majority of it). At the moment when we had an ability to implement that test, adapters like OBDLink EX/MX+ or vLinker FS were not available, so it didn't make sense to spend time for the test. Now it is a big problem to dedicate an enough timeframe for this task as there are more priority issues in the development queue. And yes, if you ultimately need this test, you have to use another software. We are sorry for any inconvenience. We are hopeful to get a chance to implement it in the near future.
I would really like to see this feature added as well and can provide or help with any info that is needed to get this implemented.
rayestes64@gmail.com
Vehicle: 2003 ford f250 6.0
Post by rayestes64@gmail.com »
I am wondering what other software would i need i have a VCM2 that use with my forscan software and it works great and i no programing issues but with working on diesels it would come in handy to have this feature but i am interested in what else i need to be able to look at cylinder balance.
