Method to disable auto stop / start found
stevenrowley
- Vehicle: Fiesta, Petrol 1.4 2012
Re: Method to disable auto stop / start found
Hi, I have managed to disable auto stop start however now I have to start the car with the clutch depressed and it comes up with the warning to press brake and clutch, I only changed in BdyCM and IPC, I have reverted this and it still stays on, if anyone can help turn this back so I can just start the car and no warning about stop start please
Reset both controllers and try again.
Lo tengo desactivado desde el bcm, desactivando la monitorizacion de la bateria del bms.
Ademas el alternador cargara tu bateria siempre al maximo.
alphamurat
- Vehicle: ford focus 1.6 tdci 2011
Hello, I own a Ford Transit 2020 model. When the sliding door is opened, the engine shuts off while in gear. How can I cancel it with Forscan?(running boards disable)?????
emrahtastemir
- Vehicle: ford transit 2020
selamlar sorunu çözebildiniz mi
As for the idea of it defaulting to off but still functional, a very simple circuit could be built that would close the circuit for a second, 30 seconds after getting power or whatever seems appropriate.
However, the install would be HUGE. Easier to buy that $99 defeat for it that plugs into the OBD-II port.
[/quote]
Yes to your last. I used the $99 defeat on my 2019 F150 King Ranch with no problem long before getting into ForScan. Worked just as advertised.
[/quote]
