Clutch learn all ok till boost learn rpm high
jayvee
Vehicle: 2011 ford focus 2ltd titanium 2ltd
Post by jayvee »
Hello all ,mine 2011 mk3 2ltd duratoq 6dct450 focus.
when using clutch learn , stroke learn ok, ventilation learn ok, until boost learn then rpm goes 1500 to 5000 on the governor and stays there until finished foot off brake and accelerator then boost learn not done, and code of p0949-00 2f, i did the learn twice and same problem,i did fork learn was all ok,any help would be appreciated.john
ChrilleB8
Vehicle: Kuga, TDCi 2,0, 2010
Re: Clutch learn all ok till boost learn rpm high
Post by ChrilleB8 »
Hello. I have the same problem. Did you solve the problem? If so, how did you solve the problem?
Most of the time it will be high rpm when ventilation learn is to start and sometimes when boost learn is to start. Anyone have any suggestions?
Thanks /Chrille
