Hello guys,
I have a question: The program can it work with simple scheme rs232 and not as elm327 adapter.
I share some smehmi for example to more clearly.
Someone tested Is such a project - communication is K-line
Share your idea on the subject.
Thanks in advance.
rs232 adapter to FORScan
californieca
- Vehicle: Mazda 626 GD
- 8.gif (9.05 KiB) Viewed 4302 times
- 7.jpg (55.94 KiB) Viewed 4302 times
- 6.jpg (34.05 KiB) Viewed 4302 times
- 5.JPG (42.18 KiB) Viewed 4302 times
- 4.jpg (39.12 KiB) Viewed 4302 times
- 3.png (17.82 KiB) Viewed 4302 times
- 2.png (1.12 KiB) Viewed 4302 times
- 1.jpg (78.64 KiB) Viewed 4302 times
Re: rs232 adapter to FORScan
Nope. Won´t work.
FORScan needs an OBD interpreter chip like ELM327, STN1170 or other ELM327-compatible.
Only thing you will get with such an interface is message "no ELM found"
