2019 ford f250 auto fold mirrors
bpogre
Vehicle: 2017 Ford F250 6.7 4x4 Platinum
Re: 2019 ford f250 auto fold mirrors
Post by bpogre »
2017 F250, swapped the 18 and 19 pins in both mirrors, changed the codes in the spread sheet. It didn’t work for me either. I did notice that it has different codes for 2 keys or 3 and 4 keys. I tried both codes and neither worked. Does it know I only have one key? Nothing changed as far as I can tell. Maybe I should try the Lincoln code.
jdespain9
Vehicle: F250 6.7l Powerstroke / 2017
Post by jdespain9 »
captainsdc wrote: Sun Apr 12, 2020 6:59 pm Although this remote auto-fold ForScan mod is shown as an F150 mod, I’m trying to set up my 2017 F250 (with towing mirrors) for the auto fold mirrors on lock. It shows the same mod on the Super Duty spreadsheet, but I am just not getting it right. I swapped pins 18/19 in both pass. and driver mirror harnesses, but no luck. The wire colors for 18/19 were close but not exactly as per the F150 noted mod, but I was assuming it would be the same as the harnesses and pins in use look identical. I’ve tried both Lincoln style and regular codes in the modules but no joy.
Anyone have similar issues and resolve it??
Scott
Did you ever figure this out? I have a '17 King ranch and after changing pins and re-writing PDM and DDM nothing. Mirrors still fold if using the button on the door.
Thanks in advance!
Jason
jdespain9
Post by jdespain9 »
Nevermind. Just turned everything off, put away all my tools, and it worked!!!!
mhays22
Vehicle: Ford F-250, Super Duty 6.7L, 2019
Post by mhays22 »
Do your flood lights under your mirror still operate the same?
erdman.bryce
Vehicle: Ford F250 6.7 Diesel 2019
Post by erdman.bryce »
Hello, just did my 2019 F250 Lariat.
After much trouble shooting, I had to use the codes from the spreadsheet (easy way didnt work).
I had to switch pins 18 & 19 ON BOTH SIDES.
This got the Autofold to work. No Lincoln
*I had to use the FC codes, not the F codes (the one for 3 or more Fobs)
Jcoyne1w3
Vehicle: F-150, 2.7 crew cab, 2018
Post by Jcoyne1w3 »
melsass wrote: Fri Jul 03, 2020 3:01 am Did you get the auto fold to work? I switched the 18 & 19 but nothing happened except one mirror goes in and the other goes out. Screwed it up.
Did you ever figure this out? My truck is doing exact same thing - 2019 f250.
Pass side mirror working as it should and driver side is complete opposite.
