2023 F150 Missing Modules
LSiebert95
Vehicle: 2013 F250 6.7L powerstroke.
Post by LSiebert95 »
Hello everyone.
Company i work for has several 2023 F150s and due to farm use we install larger tires for clearance and traction I am attempting to change the tire size so speedometer will operate correctly.
However when i connect FORScan using the OBDLinkEX cable (proper drivers and software installed) All i get are the PCM, OBDII, AIPM, ATCM and TRM modules to populate. Tried it on one of our 2022 fords and it worked no problem.
Any ideas what I'm doing wrong?
Thanks In Advance
