2023 Explorer ST Turn Signal Flashes
2020F150Limited
Vehicle: 2020 F150, 3.5L HO Limited, Rapid Red
Post by 2020F150Limited »
I acquired a 2023 Explorer ST and want to change the number of blinks from 3 to 7 with the turn signal. Has anyone found the correct asbuilt data to change this as previous gen asbuilt no longer applies and the spreadsheet that was up on icloud is gone (and wasn't correct either).
Thank you!
2020F150Limited
Re: 2023 Explorer ST Turn Signal Flashes
Just checking in to see if this still impossible? I recently bought a TOPDON J2534 passthru programmer and I am going to purchase the FDRS on the two day sub to update modules and was wondering if it was possible thru FDRS if its not through Forscan.
rbentnail
Vehicle: 2013 F150STX 4x4 5.0
Post by rbentnail »
Might be, if you can figure out which parameter needs to be changed. My truck is older so finding a table of them was no problem. I explained my process here, at the bottom of page 1 -> viewtopic.php?f=5&t=16100&hilit=parameter
Joh150413
Post by Joh150413 »
2020F150Limited wrote: Sun Jan 26, 2025 10:35 pm Just checking in to see if this still impossible? I recently bought a TOPDON J2534 passthru programmer and I am going to purchase the FDRS on the two day sub to update modules and was wondering if it was possible thru FDRS if its not through Forscan.
Doubtful if FDRS can make the change as that is not an officially supported modification.
