Beta testing Forscan for Windows
BrudnyHenryk
- Vehicle: Ford Focus MK3 1.6EB 150kM 2012
I'm testing direct config on beta 2.3.1and:
APIM direct config (Sync2) works fine for:
Ford Focus MK3 (2012)
Ford Focus MK3.5 (2016)
Ford Mondeo MK5 (2016)
Ford C-Max MK2 (2015)
Ford Kuga MK2 (2015)
BrudnyHenryk
Re: Beta testing Forscan for Windows
Known APIM Direct Config settings:
Sync2 navigation:
APIM Direct Config:
7D0-01-02 0009 0604 806D Without Navigation
7D0-01-02 0409 0604 8071 With Navigation
Sync2 climate control:
APIM Direct Config:
7D0-04-01 0103 0200 00E2 with climate control
7D0-04-01 0103 0201 00E3 without climate control
Checksum:
Last two bits are checksum in hex. If the checksum is higher than two digits, only last two digits are the result. For example:
07+D0+04+01+01+03+02+00+00=E2
Sync2 navigation:
APIM Direct Config:
APIM Direct Config:
Checksum:
Hi BrudnyHenryk,
Do you know which bytes are used with OPS( Optical Parking System) setting(s) of SYNC2 (APIM) Direct Config?
Thanks a lot,
Jason
Thanks a lot,
Jason
BrudnyHenryk wrote:Known APIM Direct Config settings:
Sync2 navigation:
APIM Direct Config:
APIM Direct Config:
Checksum:
yanxunniurou
- Vehicle: ford kuga 2.0t 2013
Same question,to await......jason wrote:Hi BrudnyHenryk,
Thanks a lot,
Jason
Sync2 navigation:
APIM Direct Config:
APIM Direct Config:
Checksum:
BrudnyHenryk
Speed camera warnings:BrudnyHenryk wrote:Known APIM Direct Config settings:
Sync2 navigation:
APIM Direct Config:
APIM Direct Config:
Checksum:
7D0-02-02 1000 0000 00EB no speed camera warnings.
7D0-02-02 1008 0000 00F3 warning of speed cameras.
7D0-02-02 1009 0000 00F4 (to be tested).
BrudnyHenryk
Rear view camera:BrudnyHenryk wrote:Known APIM Direct Config settings:
Sync2 navigation:
APIM Direct Config:
APIM Direct Config:
Checksum:
7D0-02-01 524F 0005 0080 no camera.
7D0-02-01 524F 0006 0081 camera.
ten3or
Also works on Ford Explorer (2013).BrudnyHenryk wrote:Known APIM Direct Config settings:
Sync2 navigation:
APIM Direct Config:
But no information about current street on the IPC in a mode without target.
Is this info confirmed? would changing 2nd byte in 7D0-02-01 enable rear view camera function?BrudnyHenryk wrote:Rear view camera:BrudnyHenryk wrote:Known APIM Direct Config settings:
Sync2 navigation:
APIM Direct Config:
APIM Direct Config:
Checksum:
I keep getting different answers to this question.....
ClockWorK
- Vehicle: 2015 Taurus SHO pp
- Contact:
The big thing to remember (aside from the fact that most of us are also on XDA), is that we are modifying BITs. Not bytes. Some of the posts on XDA don't make that clear.
(like, on the nav, we're not changing a byte from 0 to 4 -- we're changing 1 bit within a byte. We're changing 00000000 to 00000100. The other 7 bits might be for totally different things.)
Changing one bit to test probably won't hurt anything. But I recommend backing up your modules data with FORScan just to be safe. And have your .AB from file from Ford handy too. Worst case, you might get some DTC codes if you turn on a feature that your car can't support.
I'm pretty sure the bit I identified is for enabling/disabling the guide-lines that are displayed on the camera image when backing up. Not for the camera itself.
(not responsible if you change a bit and it makes your car explode, brick, turn into a pumpkin, or transform into a robot)
2016 F-150
720-01-01 2F0F 1064 7651 Auto Engine Off & Auto High Beam option in productivity screen present
720-01-01 1F0F 1064 7641 Auto Engine Off option absent
720-01-01 2F00 1064 7642 Auto High Beam option absent
720-01-02 221B 50B7 DTE Calculation option present in productivity screen
720-01-02 121B 50A7 DTE Calculation option absent in productivity screen
720-02-01 4DE0 3C31 1CE0 Daytime Lights option present in Settings, Adv Settings, Vehicle, Lighting
720-02-01 4DA0 3C31 1CC0 Daytime Lights option absent in Settings, Adv Settings, Vehicle, Lighting
720-07-02 0400 0034 Trailer Light Status option in productivity screen present
720-07-02 0300 0033 Trailer Light Status option in productivity screen absent
Sync 3:
7D0-03-01 0000 0003 00DE Changes highlighted menu choice to different colors (Audio, Climate, Phone, Nav, Apps, Settings) from the standard blue
Sync 3:
