Beta testing Forscan for Windows
Violakbrowne
Re: Beta testing Forscan for Windows
Post by Violakbrowne »
Thank you for all spending your time to answer this question.I too want to know about beta testing for scan for windows.
AmigaSurfer
Vehicle: Mondeo MK5 1.6l Ecoboost
Post by AmigaSurfer »
does anyone know which bit is used for Auto Speed Lock on Mondeo MK5?
races23
Post by races23 »
Should these work on a 2016 Focus ST..?
Hard_ware
Vehicle: f350 diesel 7.3l 2001
Post by Hard_ware »
Cool, years back like 9-10, eeprom dump and reprogramming bits (direct method) to configure modules was the way it was done without ford software.
The forscan software is nice, putting all the features necessary for modern troubleshooting and repair for fords (which I own a few). The j2534 pass thru connection is really fast ( old McS1 by EEPOD)
Here is a instrument cluster bit data sheet from ford back in 2007 for a f150, I installed a king ranch instrument cluster in my f150 and had to configure it by dumping eeprom and re writing it.
IC configuration data.xls
Bit break down of what does what for 2007 f150
(34 KiB) Downloaded 1183 times
Britshowboy
Post by Britshowboy »
I have enabled nav using the codes above, and disabled screen control of Climate Control - i read the values the wrong way round initally and disabled instead of verified that they were enabled.
can someone please confirm the climate control 'enable' settings for APIM module, as I think I have missed something in error. I have now set to "7D0-04-01 0103 0200 00E2 with climate control" ; the options work from the screen however the screen does not show temperature on the home screen and on/ off function does not show in Climate screen, although it works.
fiddly issue, it works ok - but is pretty annoying. I assume it is something to do with the second 7D0-04-01 setting; can you please confirm. I have a Focus 3.5.
thanks
ClockWorK
Vehicle: 2015 Taurus SHO pp
Post by ClockWorK »
It may depend on which climate features your vehicle has.
There are bits that correspond to Heated Seats, Heated Steering Wheel, AC, etc. Most of which are (i think) in 7D0-01-01, bits 37, 38, 39 (starting at zero from the left).
Ben78
Vehicle: Kuga MK3 ST-Line X PHEV
Post by Ben78 »
AmigaSurfer wrote:Hello,
720-01-01 Bit 15 (from left, beginning at zero)
pearlydougy
Post by pearlydougy »
Hi; i'm new here. Is modified elm good for using forscan, or must i have another interface?
Regards.
pearlydougy
Hi again; i have tested 2.3.4 with obdlinksx. Car is focus st 2.5turbo MK2; Log fuction is good. I can see pats option (but limited because std licence). Diagnostic function is ok too. I'm waiting the modified elm in order to test mscan.
If you want that i test another thing, keep me informed.
Regards.
sp05775ca
Vehicle: explorer ford 2014
Post by sp05775ca »
Hi thanks for all answers. I am using j-box pass thru device
worked on Explorer 2014 North American market
Performed AICM coding and bcm . Modify camera and navigation
Check all other systems work perfect
