ithinku
Vehicle: Mazda Mazda3
Post by ithinku »
Hello there
2016-06-13 my life to. I can help prolong the use of date?
It will have PCM-TCM as-built it?
Currently used in the MAZDA 2015 MAZDA 3 SKYACTIV 2.0
Thank you. Let me use such a good product
kun87
Vehicle: Focus ST170, 2.3 16v Duratec, 2005
Post by kun87 »
I've got the last version released, but I'm trying to acess this feature on my forscan, So this window where says "normal mode/engineering mode 1/ eng. mode 2" are not available to me.
Another question..
I'm trying to disable my passenger airbag via key ON/OFF only, but the only one result is all RCM system disabled, and the airbag's light won't turn off on the cluster.
NOTICE: The "Airbag Pass. OFF" light stays OFF after turn on the ignition.
Any help?
carbon
Vehicle: Ford Mondeo MK3, 1.8PB-125KM, '02.
Post by carbon »
FORScan wrote:
radkor wrote: Unfortunately RCM (SRS airbag) configuration isn't working. :(
We are aware about this issue. RCM module requires special procedure to get access to the configuration, it is not implemented yet.
Hi FORScan,
You have released a new version of your software and I see you have implemented configuration and programming procedure of RCM in Mondeo MKIV. However, I miss this functionality for Mondeo MK3. Is it going to be implemented in the near future, please?
ithinku wrote: Thank you. Let me use such a good product
You can generate new license when old one is expired, in the same way and free.
kun87 wrote:I've got the last version released, but I'm trying to acess this feature on my forscan, So this window where says "normal mode/engineering mode 1/ eng. mode 2" are not available to me.
Focus Mk2 has no central configuration. Only Mk3/3.5 have one. Please use ElmConfig for Mk2 configuration programming.
[quote="carbon"
You have released a new version of your software and I see you have implemented configuration and programming procedure of RCM in Mondeo MKIV. However, I miss this functionality for Mondeo MK3. Is it going to be implemented in the near future, please?[/quote]
We released configuration procedure for RCM of Mondeo Mk4 that has to be ran after Central configuration change. Mondeo Mk3 has
no central configuration, so it has no such a problem. What is the problem you are trying to solve, specifically?
carbon
Post by carbon »
FORScan wrote:...
I have added driver and passenger airbag curtains and I'd like to enable them in RCM module.
kobusstrydom
Vehicle: Ford Kuga 2013
Post by kobusstrydom »
Hi all
How do I get the engineering etc modes? I do not see that when I run ForScan.
fmiki
Vehicle: Ford Tourneo Custom
Post by fmiki »
Good morning!
I tried to use the central configuration on my tourneo custom but i only have this page.
The tourneo custom is not supported yet?
CrypticApollo
Vehicle: Fiesta mk7
Post by CrypticApollo »
hi
trying to add configuration to mk7 fiesta
will not in options let me write to cc
dont undersand why ? read only ?
benlatak
Vehicle: FORD Fiesta ST182
Post by benlatak »
You need extended licence for this ;)
=> http://forscan.org/forum/viewtopic.php?f=5&t=836
jc celular
Vehicle: FORD fusion v6
Post by jc celular »
HELLO, SOMEONE CAN HELP ME? I lowered my BUILT ON THE SITE WITH MY VIN MOTOCRAFT AND WHEN SHE TRY TO INSTALL IN MODULA A MESSAGE APPEARS THAT THE VEHICLE HAS NOT SOME MODELS, WOULD LIKE TO REALLY CAN PROCEED TO KNOW, I AM FROM BRAZIL FORD FUSION 2011 V6
