Page 2 of 2
Re: ipc module update error
Posted: Tue Apr 14, 2020 7:39 pm
by Harwes
update STN 1170: - from
https://www.scantool.net/scantool/downl ... -5.0.0.zip
communication port must be set to COM 1 - 3 (set in Device Manager) - other port program does not support- and baud rate 38400 - in fw update. ( or any other speed your adapter supports )
Posted: Wed Apr 15, 2020 6:19 am
by fordsmax471
Harwes wrote: Tue Apr 14, 2020 7:39 pm
very good
let's try to do
Posted: Thu Apr 16, 2020 6:55 am
by Harwes
Posted: Thu Apr 16, 2020 7:10 am
by fordsmax471
Posted: Thu Apr 16, 2020 7:57 am
by Stetsovsky
Had the same issue.
I have switched off auto speed function. put 8mbps to my scanner I use FDT
shut down the engine
and ran the program again.
everything restored.
Posted: Thu Apr 16, 2020 8:27 am
by fordsmax471
I updated manual
Post by fordsmax471 » 14 Apr 2020, 17:17
Posted: Thu Jun 04, 2020 10:49 am
by Harwes
New firmware versions for STN 2120 and STN 1170 chips have been released on Scantool.net
https://www.scantool.net/scantool/downloads/updates/
Posted: Sat Jul 25, 2020 8:56 pm
by zenon21
How long does it take to update IPC using Forscan in the 2.4 beta? I have ver. 2.4.0 20180421 and STN2120 interface.
Posted: Sun Jul 26, 2020 12:17 am
by tractmec
zenon21 wrote: Sat Jul 25, 2020 8:56 pm
Check out posts in the 2.4.0Beta thread here
viewtopic.php?f=13&t=5050 and to the note at the beginning of the thread to discover why updating firmware should not even be attempted with version 2.4.0 beta
Posted: Fri Dec 24, 2021 10:11 pm
by oaotto
Hallo
Got a problem with 2.4.5
the update was interrupted,
What can I do now ?
Code: Select all
(OK) [22:50:53.989] IPC Module firmware update wurde gestartet
(WARN) [22:50:54.003] Lese Fahrzeuginfo...
(WARN) [22:50:56.726] Unable to read current firmware p/n, use assembly p/n: F1ET-14C026-BCA
(WARN) [22:51:15.879] Total size: 7.42 Mb. Estimated duration: 36m - 1h 12m
(WARN) [22:51:23.994] Loading SBL to primary module...
(WARN) [22:51:24.297] Loading block 1/1...
(OK) [22:51:34.154] SBL loaded successfully
(WARN) [22:51:34.203] Loading firmware to ECU: Strategy F1ET-14C026-BBJ
(WARN) [22:51:34.214] Erasing block 1/2...
(WARN) [22:51:37.121] Erasing block 2/2...
(WARN) [22:51:37.346] Loading block 1/1...
(OK) [22:59:28.155] Firmware loaded successfully
(WARN) [22:59:28.195] Loading firmware to ECU: Strategy F1ET-14C026-BCD
(WARN) [22:59:28.207] Erasing block 1/1...
(ERR) [22:59:28.238] Erasing blocks failed
(ERR) [22:59:28.481] Service Prozedur fehlerhaft, bitte Entwickler kontaktieren
Gruß Otto
