Calibration files
JNEDBM
Vehicle: Mondeo, 2.0 TDCI 96 kW, 2001
Re: Calibration files
Post by JNEDBM »
Hi all,
how to find out, if an update is available?
PCM - Motorregelungs-Modul
Teilenummer: 2S7ABPK
Strategie: PUQQ5HB
Kalibrierung: 2S71-12K532-BA
Hardware type: DPC-664 / DPC-663
Copyright Visteon Corp. 2003
Brock_lh
Vehicle: Mazda BT50 4x4 3.5Turbo Diesel 2015
Post by Brock_lh »
You should be able to find your calibration files here. It worked for my Australian BT50 today..
https://www.fordserviceinfo.com/diagnos ... goryId=288
sury1217
Vehicle: transit 2.2tdci
Post by sury1217 »
hello, can i ask for calibration files for ford focus 3 bcm. DV6T-14C094-BD DV6T-14095-BD .DV6T14C403-AF . PCM .BB5A-14C273-AA .EMSA-14C204-LA .TCM AEBP-7J244-AB .DDM.AV6N-14C067-AA .HVAC. AMST-18D618-BB .BMST-18D619-BC .BMST-18D620-BL .CIST-14C319-AB or any website
oldtinfords
Post by oldtinfords »
JNEDBM wrote: Sat Oct 17, 2020 12:41 pm Hi all,
Strategie: PUQQ5HB
It'll usually tell you in the Configuration screen.
The other way to check is to go to "Configuration & programming" > Select "Module Configuration" for the module you want to update as per below & provide screen snips of the info if there's updates required.
Link to a good FREE tool for taking screen snips & editing them https://getsharex.com/
oldtinfords
sury1217 wrote: Sun Aug 20, 2023 1:18 pm hello, can i ask for calibration files for ford focus 3 bcm. DV6T-14C094-BD DV6T-14095-BD .DV6T14C403-AF . PCM .BB5A-14C273-AA .EMSA-14C204-LA .TCM AEBP-7J244-AB .DDM.AV6N-14C067-AA .HVAC. AMST-18D618-BB .BMST-18D619-BC .BMST-18D620-BL .CIST-14C319-AB or any website
I believe some of these are no longer available from Ford eg DV6T-14C094-BD, but there may be updated files available. Have a look at the last post. It'll give you an idea of what's required in order to look for updated files & ensure they are right, without wasting a heap of time. A VIN helps too.
sury1217
Post by sury1217 »
what version of fordscan is best for programming modules in ford i have elem and scanmatik i know the version of the program and where i can download tcm files. pcm bcm.
jhonstop
Vehicle: Ford Fusion Hibryd 2014
Post by jhonstop »
JG9C-14C647-SB.vbf i need.
oldtinfords
jhonstop wrote: Fri Sep 01, 2023 9:54 pm JG9C-14C647-SB.vbf i need.
File for you
JG9C-14C647-SB.ZIP
regularforscanuser
Vehicle: Ford Focus 1,6 TDCI 2012
Post by regularforscanuser »
Hi, I would be very grateful for these files:
SBL: F1BT-14C047-AD
Strategy (F188): F1BT-14C044-ZAK
Strategy (F120): F1BT-14G316-AF
Strategy (F121): F1BT-14G316-CD
Strategy (F122): F1BT-14G316-DC
ECU Configuration/Base Configuration (CAN, F10A): F1ET-14C654-CL
Thank you in advance!
aboode2010
Vehicle: 2008 5.4 FORD
Post by aboode2010 »
fordsmax471 wrote: Tue Sep 22, 2020 3:50 pm 6C1T-14C025-AB.ZIP
I need help please
I need these files
GG1T-14C026-BD.vbf
GG1T-14C088-BC.vbf
