Calibration files
GreaseMonkeyuk
Vehicle: Transit 460 2.4 140
Calibration files
Post by GreaseMonkeyuk »
Where do I download calibration files I've tryed the Ford page many many times but no matter what I put in the surch box it just comes up with file not found
Can anyone please help
Kind regards Lee
GreaseMonkeyuk
Re: Calibration files
I'm loosing the will to live with this thing can anyone help me step by step how to get this working
All I want to do is activate CC on my van but I just can't get anything to work
I have full lisance
I have genuine Bosch VCM2
I can connect no problem
I'm finally managed to get the calibration files
I tryed to put them in the directory the box asks for
That directory does not does not exist so I made it
Still getting same error that file not found
Can anyone help please I'm dyslexic I've tryed help pages but I can't make heads or tails of if
Post by tractmec »
GreaseMonkeyuk wrote: Sat Aug 15, 2020 3:13 pm I'm loosing the will to live with this thing can anyone help me step by step how to get this working
I have full lisance
I Will attempt to help you!
This may be an obvious question but did you extract the calibration file or files into or in that directory and file folder you made or did you just copy the file you downloaded to the directory and file folder you made?
I am assuming you made the directory and folder as directed in this topic viewtopic.php?f=16&t=1932#p8036.
And if you downloaded the Archive file at the Link http://forscan.org/download/CalibrationFiles.zip, did you extract it as outlined below and as instructed to do so, into the folder you made?
You should be able to navigate through something like this upon opening your Windows file explorer. "Computer" to "Local Disk (C:)" to "Users" to "[yourusername]" to "MyDocuments" to "CalibrationFiles" to "[7G9T-14C097-AA.vbf]". Your user name should be where the first set of brackets are and the calibration files you downloaded should look something like the file name in the second set of brackets.
That is not likely to be the file you need. Forscan was likely asking for a similar looking file name in that error message it has been showing you and that you said you managed to get and try to put into to the directory folder you made.
I just picked that one at random from the archive I have as an example of what the file names should look like.
The files, if you downloaded them from Ford, at this link https://www.fordtechservice.dealerconne ... roduct=IDS or in the Forscan archive above, are in a .zip compressed archive and must be extracted by another program!
Forscan does not have a file extractor to unzip these itself. I think Fords IDS does.
Open your windows file explorer, navigate to the folder you made as above and check whether that folder you made has any file name that ends in .zip .vbf or .ab or if it even has a file name in it. If it does have a file name and it ends in ".zip" then that is the problem, it must end in .vbf or .ab in order for Forscan to recognise it as an SBL calibration file or as an asbuilt file!
If there is only a .zip file currently in that folder you made, then you should be able to extract it by right clicking on the .zip file and clicking "Extract All" in the Windows File Explorer context menu. This works in Windows 7 Pro. Should be the same in Windows 10.
A warning about files downloaded from the internet being harmful may pop up, just click OK and continue as these are safe and are not Malware or viruses!
If there is no file in that folder then look again in your file downloads location for the .zip file Forscan has been asking for and extract it to your 'MyDocuments folder.
If a message pops up asking what program to use to extract the file, then you will need to download a little program called 7zip and install it and use it to extract the .zip file or .zip archive into or in the folder you made!
You should not have to though, as archive file extraction has been a part of the Windows Explorer right click menu since Win XP!
Let's see if that helps you with a little more will to live!
geebee0316
Vehicle: Escape 2.0L GTDI EcoBoost 2015
Post by geebee0316 »
I also cannot download any calibration files, every attempt results in a file named "DSFM_DownloadFile.asp" which is a tiny little file that contains an error message... I thought opening that file with Internet Explorer might possibly go on to download the file but no joy.
I would sure appreciate any help.
By the way, I am using an OBDLink EX and I like it very well.
geebee0316 wrote: Sat Sep 12, 2020 10:23 pm I also cannot download any calibration files, every attempt results in a file named "DSFM_DownloadFile.asp" which is a tiny little file that contains an error message... I thought opening that file with Internet Explorer might possibly go on to download the file but no joy.
We confirm it doesn't work anymore. Any attempt to download a files returns "DSFM_DownloadFile.asp". it is not really clear for now if this is a malfunction on their server that will be resolved earlier or later, or they don't want people to freely download calibration files from this page (that would be strange as this page is specially designed for it).
geebee0316
Wow, what a bummer.
Thank you for the quick response, are you the creator of FORScan?
Paulscarbs
Vehicle: Transit 2.4 RWD
Post by Paulscarbs »
Trying to download SBL calibration file
6C1T-14C025-AB.VBF
Any ideas how I can access this please?
6C1T-14C025-AB.ZIP
armsdigital
Vehicle: Fiesta 2014
Post by armsdigital »
fordsmax471 wrote: Tue Sep 22, 2020 3:50 pm 6C1T-14C025-AB.ZIP
Hello, would you help me to get below files?
I have tried to find in motorcraft website and could not find them.
I know its many, but anything you have would be very appreciated!
F1FT-14D049-AC
F1FT-14G012-AC
AG9N-14C175-BA
BV6T-14C172-BF
BV6T-14C173-BC
BV6T-14C411-BA
CV6T-14C217-AR
CV6T-14C218-AX
AV6N-14C107-AB
AV6N-14C104-AN
AV6N-14C105-AK
AV6N-14C430-AE
BM5T-18D619-BE
BM5T-18D620-BE
AV6T-14D370-AB
AV6T-14D368-AF
AV6T-14D369-AD
AV6N-14367-AA
AV6T-14D370-BB
AV6T-14D368-BF
AV6T-14D369-BD
AV6N-14D367-BA
C1BT-14C026-AU
C1BT-14C088-AU
SYNC USB
AM5T-14D544-LF
AM5T-14D544-HE
Thank you
PM
