MK3 Focus ABS reprogramming without access to original ABS
Fox06
Vehicle: 2012 Ford focus 1.6ti-vct
Re: MK3 Focus ABS reprogramming without access to original ABS
Post by Fox06 »
HI, I have done the PATS initialization and also reprogram my keys. but still no start. still say immobilizer malfunction service required,
now i have the following DTCs:
===PCM DTC U0418:00-2F===
Code: U0418 - Invalid Data Received From Brake System Control Module 'A'
Status (-2F):
Freeze Frame #1:
-EVENT_TIME: 412733350 s ((null)) - Event time
-TOTAL_DISTANCE: 85756 km - Total Distance
-MODULE_VOLTAGE: 13.0 V - Control Module Voltage
-INCAR_TEMPERATURE: 23 °C - In car temperature
-OUTDOOR_TEMPERATURE: 26 °C - Outside temperature
-PWR_MODE_KEY: Ignition On - Power Mode Key State
===END PCM DTC U0418:00-2F===
===BCMii DTC B10DA:51-2F===
Code: B10DA - PATS Target Identifier
Additional Fault Symptom (:51):
- Not Programmed
Status (-2F):
Module: Body Control Module
Freeze Frame #1:
-EVENT_TIME: 412733322 s (Sun Feb 15 12:32:40 2026) - Event time
-TOTAL_DISTANCE: 291601 km - Total Distance
===END BCMii DTC B10DA:51-2F===
===BCMii DTC U2101:00-2F===
Code: U2101 - Control Module Configuration Incompatible
Status (-2F):
Freeze Frame #1:
===END BCMii DTC U2101:00-2F===
Please help🙏
Fox06
Post by Fox06 »
OK, So an update. I managed to get the car statred and the immobilizer malfunction went away.
What i did.
1. PATS for the the keys to be reprogrammed(Still didnt work)
2. Deleted the car's profile.
3. did the PATS program again.
4. turn the key in the ignition on/off for about 3 times
then all was well :D
Hope this helps someone with the similiar issue when changing one of the modules thats related the PATS system.🙏
