Page 2 of 2
Re: MS-CAN inaccessible on Mondeo Mk3 TDCi (ELS27, or vLinker FS USB w/OBD-extension)
Posted: Fri Feb 21, 2025 10:29 pm
by pswiatki
I will check the label in the morning and let you know.
If memory does NOT serve me wrong - it is FMBA. 2006 TDCi 96 kW / 130 PS, 1998 ccm. By the way: Delphi injection system.
Posted: Fri Feb 21, 2025 10:53 pm
by pswiatki
tractmec wrote: Wed Feb 19, 2025 10:51 pm
Don't know if that is an answer to your question or not?
Well.... Sort of, kind of. You see: I used to work for Delphi as a software (embedded) developer for the past 20+ years. I have some knowledge in communication buses, etc. But I do not know the actual arrangement in my particular vehicle (never had access to any Ford docs to verify my suspicions).
Regarding the PID cyclic reads - the only thing I wasn't sure about was the multi-bus operations. I understand that querying on a single bus, if only the interface (that is: the bridge between any of the car's buses hooked up to the OBD connector) is fast enough, it will work nicely. I am not immediately sure how well such a device (the bridge interface) handles multiple communication buses (say: CAN and J1850 PWM and K-Line ISO 9141-2) simultaneously. As far as I can tell from the warning in Forscan - there could be issues with that (perhaps it is of real concern to those who use the interface with a mechanical CAN switch).
The data throughput is not really a problem for a relatively modern PC. This much is obvious to me, yes.
Posted: Sat Feb 22, 2025 4:24 pm
by boosted_diesel
pswiatki wrote: Fri Feb 21, 2025 10:29 pm
ok not sure if your car is hatch, saloon, estate/wagon.
the diagram below is for the DLC for the hatchback.
- mondeo diesel 2006 dlc.png (99.41 KiB) Viewed 3698 times
this is for the CAN BUS high speed
- 2006 modeo diesel can high.png (68.34 KiB) Viewed 3698 times
Posted: Sat Feb 22, 2025 4:57 pm
by pswiatki
It is a hatchback. Thank you much! The diagrams are too small - not possible to read wire markings.
Posted: Sat Feb 22, 2025 10:04 pm
by boosted_diesel
All of the pin numbers are on the diagram. I can see them using my cell phone.
Posted: Sat Feb 22, 2025 10:18 pm
by pswiatki
Yeah, I can see those, too. But cannot enlarge to make them easy to read. The resolution is kind of low. Would it be possible for you to print out those two diagrams and share with me (if not here - then privately)?
Interestingly, the DLC does not show any connections to pins 3 and 11 (which are expected to be wired to the MS-CAN bus) in these diagrams. As we can see above, Forscan finds modules on that bus and can communicate with them.
Posted: Sun Mar 16, 2025 11:28 am
by boosted_diesel
If you still need the diagrams give me a shout I can probably email them to you or something.
