IJY1992 wrote: Fri Jan 23, 2026 4:09 pm
Hi can anyone help me get hold of EK31-14C204-ANH or a newer version of it? just replaced a PCM on a MK8 FWD Transit with a used one and cant seem to get my hands on the correct firmware. it seems forscans built in downloader will only allow me to download a version that is compatible with the currently installed software rather than one that's compatible with the van
Hello everyone! Last year i made a mistake to update my firmware for door modules (pdm and ddm) and it was worse for me that my rear one touch windows stop working as one touch they are opening with every press some inches.
Its around one year to wait for the correct firmware but its not available now. So i need correct data for my door modules if anyone have similar.
devn89 wrote: Sat Jan 24, 2026 11:47 am
I own Ford focus ST line 2016-2017 EU .
Thank You in advance
What firmware files does FORScan show are needed? Do you have a paid licence & 2.4.20 to download the files?
daisycutteruk wrote: Sun Jan 25, 2026 8:04 pm
Hi all,
Reading this thread and have same issue trying to download the file
I am looking for : DV6T-14C097-AB
Any help appreciated
I saw a post elsewhere & it looks like you've made the same mistake as many other people. The file has likely downloaded & saved wherever you told it to save to & you haven unzipped it to the folder shown in your image on FB. The file is also in the files section of the FB group.
Hello there fellow ForScanners, i'm looking for the KK3A-14C204-AVL vbf file if someone has it and if not, then the latest available update before AVL which is AVK will do.
2017 Cab and Chassis F350 6.7L Diesel needing to re-calibrate ECM and TCM to Stock pickup calibration (NOT Cab and Chassis) found a vin same year and configuration in a pickup.
Current VIN: 1FD8W3HT0HEE91701
Needed Cal files for VIN: 1FT8W3DT7HEB27656
Current Cal level available are
K3A-12A650-BDA
K3A-12A650-BDB
K3A-12A650-BDC
K3A-12A650-BDD
K3A-12A650-BDE
K3A-12A650-BDF
K3A-12A650-BDG
K3A-12A650-BDH
