Page 12 of 12
Re: Calibration files
Posted: Thu Jan 29, 2026 7:22 am
by oldtinfords
Victorson wrote: Wed Jan 28, 2026 11:43 pm 2017 Cab and Chassis F350 6.7L Diesel needing to re-calibrate ECM and TCM to Stock pickup calibration (NOT Cab and Chassis) found a vin same year and configuration in a pickup.
Current VIN: 1FD8W3HT0HEE91701
Needed Cal files for VIN: 1FT8W3DT7HEB27656
Current Cal level available are
K3A-12A650-BDA
K3A-12A650-BDB
K3A-12A650-BDC
K3A-12A650-BDD
K3A-12A650-BDE
K3A-12A650-BDF
K3A-12A650-BDG
K3A-12A650-BDH
The asbuilt file for VIN: 1FT8W3DT7HEB27656 shows the calibration as HC3A-14C204-ABJ
NODEID [17]
0 {6}
1 {7}
2 {7}
3 {6}
F110 : DIAG PART AND REV NUM
F111 : HC3A-12B684-BA
F113 : HC3A-12A650-JC
F188 : HC3A-14C204-ABJ
F18C : 780505216233
__text : 7E0
Link to HC3A-14C204-ABJ & asbuilt file https://disk.yandex.com/d/fgKt4E-oJ7JKPg
Load the asbuilt here & search 7E0 or 14C204 or 12A650 to find the PCM info
https://jsonformatter.org/xml-viewer
Posted: Wed Feb 11, 2026 12:52 pm
by IJY1992
oldtinfords wrote: Fri Jan 23, 2026 8:03 pm
IJY1992 wrote: Fri Jan 23, 2026 4:09 pm Hi can anyone help me get hold of EK31-14C204-ANH or a newer version of it? just replaced a PCM on a MK8 FWD Transit with a used one and cant seem to get my hands on the correct firmware. it seems forscans built in downloader will only allow me to download a version that is compatible with the currently installed software rather than one that's compatible with the van
Download link for EK31-14C204-ANH
https://disk.yandex.com/d/QHNxNW3LaiT37w
Thanks very much
Posted: Wed Feb 11, 2026 1:00 pm
by IJY1992
Hi Does anyone have NK21-14C625-ALE or newer variant. doing a PCM replacement on a crash damaged Automatic 2023 transit custom .
Thanks in advance
Posted: Tue Feb 17, 2026 1:00 am
by BesiZ
VBF for upgrading the 1.6 TiVCT Fiesta mk7 from 105 hp or 120 hp to 134hp.
link to BV21-12K532-LC: https://mega.nz/file/ZnBFBRhB#sBZIbjfb4 ... glX4y02tPc
Posted: Tue Mar 03, 2026 3:45 pm
by bikerlife82
Can anyone provide these calibration files for abs and bcm focus mk3.5?
abs: F1FC-2C405-AM
bcm: GV6T-14A073-EL
Posted: Wed Apr 01, 2026 10:26 am
by tonik8242
Hi. I am looking for files to CCMii S-max/Galaxy/Mondeo 2011-2015: BG9T-14B588-BC; STRATEGY: BG9T-14C172-BC; CALIBRATION: BG9T-14C173-BB. Or similar. Can anyone help?
