No. I don't have it,... I bought JDiag Elite-II as a little cheap and reliable, anybody who use this device please share their experience to me
thanks in advance.
thanks in advance.
Even I tried on VINT the same thing happens, I tried it on FORD Fiesta 2010 model with Siemens ECU the programming and service procedure is not available, what could be the problem
Hello.
Today I used klon mongoose jlr plus (SP-205c with orginal driver for windows 7 64 bit) with forscan 2.3.29 beta. I conected with ford focus St mk4 it's perfectly worked.
There is another adapter used with FORScan. The original VCM I was tested and passed similar to:
CarDAQ Plus
CarDAQ Plus 2
CarDAQ Plus
CarDAQ Plus 2
- 1st test
- Test 01.JPG (230.82 KiB) Viewed 15707 times
- 3rd test
- Test 03.JPG (110.48 KiB) Viewed 15708 times
- 2nd test
- Test 02.JPG (133.28 KiB) Viewed 15708 times
- VCM 1 Connection
- VCM 1.jpg (192.07 KiB) Viewed 15708 times
- 1st test
- Test 01.JPG (230.82 KiB) Viewed 15708 times
- 3rd test
- 2nd test
I have JDiag elite pro II test it with Xentry and DAs and VIDA and Forscan all good will test it more when i have timedevele wrote: Thu Feb 06, 2020 4:33 am No. I don't have it,... I bought JDiag Elite-II as a little cheap and reliable, anybody who use this device please share their experience to me
thanks in advance.
I have a Cardaq plus 1 and 2 along with original VCM II. Which one will work best with this program. Also, does this do flashing like IDS and FJDS? Or is flashing/programming only done through Ford? Thank you! New here.
aircraftru
- Vehicle: Insignia, A20DTE, 2000cc/96kW, 2014
Did someone is run MDI interface? Is work with GDS, but can’t figure way to run with ForSCAN
I've been using a 2 board clone VCM2 with our 2013 Kuga.
Has worked flawlessly with FORScan, did a Powershift TCU furmware update in less than 5 minutes without issue.
Wasn't the cheapest available, sourced from Germany but works a treat.
CantieCAR Ford mondeo body module programming "CAN bus compatibility problem"
any solution ??
any solution ??
- error.jpg (156.02 KiB) Viewed 14959 times
raftrading
- Vehicle: transit 2200 tdci 2007
Has anyone tried a autel maxiflash j2534? I can't get forscan to find mine?
