Page 14 of 29
Re: REMOTE START
Posted: Thu Jan 20, 2022 5:23 pm
by rob225
Do you have this key, if so what is the range like, I purchased another one (https://www.aliexpress.com/item/4000835 ... 4c4dXNEEOI) and the range is really poor.
Also does anyone know if it easy to delete the 3rd programmed key, do you just follow the first post and just not use the key you don't want programmed?
EDIT: Forgot to say its a Mondeo MK5 UK spec
Also what is the max number of keys?
Re: REMOTE START
Posted: Fri Jan 28, 2022 1:17 am
by nicomartinezf
Hi I've a problem with the remote start, the start impulse it's not enough and the car doesn't start. Do you know how to make it work.
Re: REMOTE START
Posted: Fri Jan 28, 2022 1:20 am
by nicomartinezf
Re: REMOTE START
Posted: Sun Jan 30, 2022 6:48 pm
by TRIROG
flashedbg wrote: Wed Jan 12, 2022 9:11 pm Hello guys and thanks for the information.
So i purchased a key from AliExpress(CNAuto) and I successfully managed to add the key and program the BCMii and IPC. Unfortunately the new key(3rd key) is only working after changing RTM Module 751-01-01 000X 0000 to 2. If i leave X to 1 then the new key isn't working, If i change X to 2 the new key with the remote start is working but the old 2 keys are working only as emergency. Is there any way to make all the three keys to work simultaneously?
Hi!
Can you give your original key part number and the part number you ordered, your car model and your region EU/UK/US...
Did anybody with S-max except user @fordsmax471 manage to get the key form CNauto working witout mods to RTM?
I'm looking into buying the key from cnauto but i need the other keys to work because my wife and i each use one key (so RTM mod not possible).
What is the key part # that you purchased?
My original key part # is HS7T-15K601-DC
I guess the replacement # is HS7T-15K601-ED/ DS7T-15K601-EF but i just wanna confirm before ordering.
Thanks!
Re: REMOTE START
Posted: Mon Jan 31, 2022 6:24 am
by mafteiucatalin
Hy i have edge 2017 powershift and the car dont start when i pres look and 2x start only horn,i make all changes in ipc bcm rtm and reset all,the key is h87t-16k601-ee,could be the problem that i make the rmt too ,in the tutorial say to make only rtm if not works,i dont try if it work only with modification on bcm and ipc,i make all 3 changes togheter
Update i think is a problem with hood switch in forscan was enable, i dont make this change,was,but dont work i think is damage,dont show in cluster when is open or close
Re: REMOTE START
Posted: Mon Mar 07, 2022 1:35 pm
by ferdideboer
Hi all,
I just wanted to let you know that I have succeeded in programming a remote-start-key that I bought from AliExpress (CN18093 HS7T-15K601-ED/DS7T-15K601-EF Smart Remote Proximity 433.92Mhz).
I followed the directions as described by TS. I now have 3 Admin keys: 2 original and 1 RS key, and they all work!
At first I thought that the RS didn't work (locks and boot worked), so I tried to program the RTM, but then all three keys didn't work, so I changed back the RTM with the new key in the key-slot.
After that I tried again and tadaaaaaa! Success!
A big shout-out to @fordsmax471 for to he instructions, thanks mate 👍🏼
Re: REMOTE START
Posted: Mon Mar 07, 2022 2:21 pm
by fordsmax471
ferdideboer wrote: Mon Mar 07, 2022 1:35 pm Hi all,
Re: REMOTE START
Posted: Fri Mar 11, 2022 11:44 am
by xpert
rob225 wrote: Thu Jan 20, 2022 5:23 pm Do you have this key, if so what is the range like, I purchased another one (https://www.aliexpress.com/item/4000835 ... 4c4dXNEEOI) and the range is really poor.
I also purchased remote key from mentioned seller, and i can confirm that range is very poor. Range is maybe 10m. Remote start is hit or miss, i would say 50/50 chance that remote start is successful. Buttons are not as nice as on original remote. And when you look at PCB (green board with buttons and chip and antennas ) inside key, it is different design than genuine key. PCB in this chinese key is not potted against moisture, i also see that as negative.
Range of original remote is over 100m.
Re: REMOTE START
Posted: Tue Mar 15, 2022 7:33 pm
by ferdideboer
xpert wrote: Fri Mar 11, 2022 11:44 am
I don;'t know if this will help you in any way, but here's the link to the key I bought AND successfully programmed as third admin key AND got Remote Start to work.
https://www.aliexpress.com/item/1005002 ... 18029nFXNk
Best regards,
Ferdi
Re: REMOTE START
Posted: Mon Mar 21, 2022 3:56 pm
by rob225
ferdideboer wrote: Tue Mar 15, 2022 7:33 pm
Best regards,
Ferdi
Thanks @ferdideboer,Did you buy the original or aftermarket and does the key work from a good distance?
Also did you have to change RTM module AsBuilt value 751-01-01 to x2xx xxxx?
Rob
