REMOTE START
bean
Vehicle: S-max 2016, 2.0TDCi, Powershift
Re: REMOTE START
Post by bean »
Hi, everyone.
First want to say big thank you to @fordsmax471 and all contributed to this thread.
My feedback in brief.
Car - Ford S-Max 2.0 TDCi 2016 PowerShift
I live in Bulgaria, but the car was bought from Italy.
My original keys are part number DS7T-15K601-DD and I've bought this one
CN18093 HS7T-15K601-ED/DS7T-15K601-EF Smart Remote PROXIMITY Key 433.92MHz FSK Transponder for Ford
from aliexpress ( https://www.aliexpress.com/item/1005002 ... f19cNj8Cih )
Followed all the steps described here on the thread.
Successfully managed to add new key.
Unfortunately I have to change RTM settings since new key worked only in backup slot.
After change of RTM new key is able to lock/unlock and start the car, old keys work only in backup slot.
I did all changes in IPC and BCM modules with Forscan.
Reset all 3 modules.
But Remote start not working!
Tried with press lock button once and than double press 2x - no success.
Only double press 2x - no success.
Nothing happens!
I reread the whole tread and see that fordsmax471 mentioned something about enable remote start in IPC menu with buttons on the left of steering wheel
but i have no such menu in IPC panel on the dashboard.
Any ideas will be highly appreciated.
P.S. Someone mentioned the car battery is important, i am not sure how to check this, battery seems to be fine, since i have no troubles starting the car normal way even in cold weather now ( around 0 degrees )
P.S.2 Auto Start/Stop is disabled via forscan if this is of some importance.
:!: EDIT: After Remote Start enabled in IPC menu. :idea: Option For "Remote Start" in Instrumental Panel appeared :idea: . Once Enabled everything works as expected, Remote start is working! :mrgreen:
kovlo
Vehicle: 2017 Galaxy 2.0 Tdci Powershift
Re: REMOTE START
Post by kovlo »
bean wrote: Fri Dec 02, 2022 12:01 pm :!: EDIT: After Remote Start enabled in IPC menu. :idea: Option For "Remote Start" in Instrumental Panel appeared :idea: . Once Enabled everything works as expected, Remote start is working! :mrgreen:
Congratulations!
I took some pictures in the morning of my instrument panel menu, what I just wanted to upload for you.
I'm glad you solved it and it works!
Enjoy the preheated car!
slip_n_slide
Vehicle: Ford Mondeo 2.2 Titanium X Sport 2010 (59)
Re: REMOTE START
Post by slip_n_slide »
Hi all, so I’ve been using remote start a bit in the cold weather, very useful to clear the screens. A couple of issues though….
Main one is the alarm goes off occasionally while the car is running. So I haven’t gone to it or opened the door and locked it again, just hit lock and start on the key to get it running. Does anybody have any ideas how I can stop the alarm from sounding as I leave for work at 5am and don’t want to upset anyone.
Also, everything else works fine except my heated seats. Again,
Does anyone have any ideas that could point me in the right direction for a warm ass in the morning.
Thanks in advance to everyone , and specifically to FordSmax471 for all the guidance on this thread.
Edit: car is a 2016 S-Max tit sport 210 auto
kovlo
Re: REMOTE START
Post by kovlo »
slip_n_slide wrote: Fri Dec 09, 2022 9:10 am Also, everything else works fine except my heated seats. Again,
I don't have alarm, but I have similar behavior with the seats. I'd be interested in the solution ideas as well.
The seat and steering wheel heating does not turn on remote start for me, although their option in the RS menu is set to Auto in the IPC. I tried with RS Climate control settings option both in Auto and Last settings selected. The external temperature was around 0°C.
slip_n_slide
Re: REMOTE START
slip_n_slide wrote: Fri Dec 09, 2022 9:10 am Hi all, so I’ve been using remote start a bit in the cold weather, very useful to clear the screens. A couple of issues though….
As an update to this I have been setting the alarm to reduced when I know I'll need remote start early in the morning. This has stopped the alarm from going off, but it would be good to sort it in a way so I don't have to keep changing it back if I need to go back to the car for something. :)
niktro
Vehicle: Ford Mondeo 2,0 bi-tdci 211hp, 2016
Re: REMOTE START
Post by niktro »
Hi Guys, I have a little question.
Car: Mondeo 2016 EU
I bought from aliexpress this key CN18093 434.92Mhz.
Someone said, that the original keys and the remote start key will work, if the frequency is the same, but I need to change in rtm modul to work, but than the 2 original keys don't work. Did the guy send me the wrong key or is this a fortune things 🤔.
johnmozley
Vehicle: mondeo 2ltr 150bhp 2016
Re: REMOTE START
Post by johnmozley »
hi can this remote start be used on a 2016 mondeo with sync 2 powershift box thanks
Re: REMOTE START
johnmozley wrote: Tue Feb 28, 2023 8:12 pm hi can this remote start be used on a 2016 mondeo with sync 2 powershift box thanks
yes
Thebigjack91
Vehicle: Ford Edge 2016 2,0 209cv
Re: REMOTE START
Post by Thebigjack91 »
sorry for english, i use google translate. I performed the procedure and after various problems to configure the new key, it always gave me a programming error, until I then reset the 3 modules and then the programming went successfully. I just have to change the RTM module from 1 to 2, isn't there another solution? so I avoid losing the 2 keys?
Re: REMOTE START
have you already tried a new key, this key opens and closes the doors or not ?
if not, the only option is to change the as built data in the RTM module.
after changing the RTM module if it won't open and close the doors, your new key has the wrong frequency
