REMOTE START
Thebigjack91
Vehicle: Ford Edge 2016 2,0 209cv
Re: REMOTE START
Post by Thebigjack91 »
The new key I bought on Aliexpress only works if I change the RTM module, but the other 2 do not. Isn't there a solution to make all 3 work? I also noticed that 4 keys are registered in my car including the new one. I and I only have 2 originals. Is this normal or do I have to ask the Ford? Can I delete it with Forscan?
Demen25
Vehicle: Kuga 1.8 Powershift
Re: REMOTE START
Post by Demen25 »
Hello all.
I have a KUGA Vignale with Powershift, but I can not program the new 4 button, although I tried the 2 procedures. Is there a technique with forscan?
I bought this model of key.
Sarindy Vong
Vehicle: Ford Ranger, Mazda BT 50, F150, M2,M3,CX-9
Re: REMOTE START
Post by Sarindy Vong »
how to enable remote start for ford ranger wildrak 2023 new generation ?
mehmetmsm
Vehicle: Ford Ranger NextGen Wildtrak 2.0 2023
Re: REMOTE START
Post by mehmetmsm »
Hello, I've got a nextgen Ford Ranger Wildtrak 2023 with 2 button key fob HC3T-15K601-DD 434MHz. Can someone help me about which key fob to purchase so I can use it for remote start?
I read on some forums that remote start frequency is 902MHz. Should I purchase a key fob with 434MHz or with 992MHz.
Thank you.
Memo
colin39
Vehicle: ford ranger 3.2cc 201bhp 2019
Re: REMOTE START
Post by colin39 »
mehmetmsm wrote: Sat Jul 22, 2023 8:57 am Hello, I've got a nextgen Ford Ranger Wildtrak 2023 with 2 button key fob HC3T-15K601-DD 434MHz. Can someone help me about which key fob to purchase so I can use it for remote start?
Thank you.
Memo
434mhz once you have programmed it , you need 2 keys the go into build and go into as build and rtm module line 751-01-01 01F0 change it to 02F0 you original key will no longer lock or unlock but your programed new key now will.
Follow and Like I have done an insta vid of me doing it on my 2020 plate
https://www.instagram.com/reel/CvSEATHI ... M1YmI2Ng==
colin39
Re: REMOTE START
Post by colin39 »
Sarindy Vong wrote: Mon May 08, 2023 3:04 pm how to enable remote start for ford ranger wildrak 2023 new generation ?
The same as my 2020 plate you should have remote start through the app so you just need to adjust the line in the rtm module
colin39
Re: REMOTE START
Post by colin39 »
Demen25 wrote: Sat Apr 29, 2023 1:06 pm Hello all.
As long as you have remote start on the app the probably the same as the above
colin39
Re: REMOTE START
Post by colin39 »
Thebigjack91 wrote: Thu Mar 02, 2023 8:23 pm The new key I bought on Aliexpress only works if I change the RTM module, but the other 2 do not. Isn't there a solution to make all 3 work? I also noticed that 4 keys are registered in my car including the new one. I and I only have 2 originals. Is this normal or do I have to ask the Ford? Can I delete it with Forscan?
Which car?
Yes you can delete keys but you delete all, as the others don't work just get another remote start key and faraday box the remaining
mehmetmsm
Re: REMOTE START
Post by mehmetmsm »
colin39 wrote: Thu Aug 03, 2023 8:34 pm
Thank you.
Memo
Thanks for the guidance.
I've bought a key fob from AliExpress based on the product commens(link is at the end) and all key buttons including remote start is working without additional Forscan programming, I've just programmed the key using original keys according to user manual within the truck. Original keys are also working. Anyone with Next-Gen Wildtrak can have a look.
https://a.aliexpress.com/_Eu8ZANh
Mehmet
colin39
Re: REMOTE START
Post by colin39 »
If you have remote start in Ford pass app then it'll all work.
Here in the Y-uk that line I said adjust needs to be done to recognize the multifunction key, our keys just lock and unlock
And my car is also the preface lift 2020 car https://photos.app.goo.gl/D3wvZyFTYqc7MF1c9
https://photos.app.goo.gl/bcQmNyCVckKk5fpz7
