Kicker subwoofer and 727-01-02
James1374
Vehicle: Ford F150 3.5L 2020
Re: Kicker subwoofer and 727-01-02
Post by James1374 »
The xxx's in the first line are to be left alone as well.
pagan696
Vehicle: 2020 F150 STX 4x4 SuperCab
Post by pagan696 »
James, MY MAN!
thank you, and everyone else on this thread, so much for your assistance. spelling it out in layman's terms so that a novice like me could figure it out.
the 727-01-02: 0088-B9xx-xxxx adds the low pass crossover and the system sounds sooooooo much better. it took a little bit of loading and tinkering to better understand how FORScan works. the sound quality has greatly improved and is at a point i feel is correct (given the limitation of a small amplifier and 8" woofer).
i was even able to add the Bambi mode successfully (fogs on with high beams).
i hate it took so long for me to be able to resolve, but very glad this forum exists for mods and tweaking.
mentzer814
Vehicle: 2018 f150 3.5
Post by mentzer814 »
So is It all good now was that in the acm config
pagan696
Post by pagan696 »
it is good now. the "error fix" in 727-01-02 activates the built-in crossover in the ACM.
MarkPelszyk
Vehicle: 2019 F-150
Post by MarkPelszyk »
I installed the kicker sub n my 2019 xlt with 7 speakers. I used these FORScan 727-01-01 xxx8 xxxx xxxx - Auxiliary External Subwoofer
727-01-02 0088 B9 - Kicker/Subwoofer Selection "error" When I changed the value in 727-01-01 to xxx8 xxxx xxxx it made my ACM say that I’m using 6 speakers and not 7 speakers. The dash speaker does not work when I change the value to xxx8. When I have a xxx9 in place the center dash speaker works. Does the center speaker dash need to be disabled? forscan reading
- auxiliary external subwoofer: enabled
- engine noise enhancement: disabled
- kicker install: 6 speaker - kicker should be 7????
- mute radio: disabled
nightraven
Vehicle: Ford Ecosport 1.5 Diesel
Post by nightraven »
Please read through my post
https://www.forscan.org/forum/viewtopic ... 16&t=16150
I hope it helps you. You can try changing the Speaker Configuration option to "10 High Series Speakers with Subwoofer".
jdegiuli13
Vehicle: 2022 Ford F150 Raptor
Post by jdegiuli13 »
Crunchtime2k wrote: Tue Apr 21, 2020 12:11 pm I do have a fix for the weird muffled , muddy , low quality and low volume sound on the 19 and 20 B&0 systems.
It requires 3 changes if I remember to a few diff modules , acm and dsp , I will dig out my notes later today and help if needed still.
Can you post your data for acm and dsp modules also your trucks config , BO super crew or super cab
How can I get these changes needed!
japapoe
Vehicle: 2020 F550 6.7L Diesel
Post by japapoe »
How does nightraven have all of those options available in his ACM config and I only get the basic 4 to select mute, engine noise, number of speakers. How do I get the flat EQ and all that other cool stuff? I just installed my kicker 8” factory sub on my 2019 XLT
japapoe
Post by japapoe »
jdegiuli13 wrote: Sun Mar 13, 2022 12:34 pm
Any luck here?
spiphus
Vehicle: F150, 2.7 Ltr , 2020
Post by spiphus »
Any update on the equalizer settings?
japapoe wrote: Thu Jul 07, 2022 10:50 am
Any luck here?
